EXTRUDER CONTROLLER(2 THERMISTOR TYPE)
SKU 102990086
59.00
DISCONTINUED
This extruder controller card is a temperature monitoring and PID temperature controller for 3D printers. If you have a desktop CNC machine you can easily convert your CNC to a 3D printer with this controller card. You can also handle your temperature related tasks of your 3D printer with this card without the need of a computer.
You can set both the extruder temperature and the heated bed temperature with on board trimpots. You can read digitally your set temps and sensor values from the LCD. You can directly connect your heating elements to the board. High Power MOSFETS can handle your current requirements.
Project Web Page
Features:
  • Standalone No PC Connection Required
  • Based on the Arduino Diecimila
  • 2×16 LCD Display
  • Simple Temp Settings With Onboard Pots
  • 2 High Power MOSFET Outputs (5A at 12V)
  • 2 Thermistor Input
  • Needs 12VDC as power source
  • 2 independent PID Computation Via On-board Micro-controller
Important:
It is important to use a proper power supply according to your current needs.
Connection Diagram:
Suitable Heating Element:
You can use (6R8 Ohm RESISTOR 7W 5% ) as heating element with this controller board.
  • Resistance: 6.8ohm
  • Resistance Tolerance: ± 5%
  • Power Rating: 6W
  • Voltage Rating: 350V
  • Temperature Coefficient: ± 75ppm/°C
  • Resistor Element Material: Wirewound
  • Resistor Terminals: Axial Leaded
  • Resistor Mounting: Through Hole
  • External Length / Height: 18mm External Width: 6.5mm
  • Operating Temperature Range: -55°C to +350°C
  • Package / Case: 6 x 22
  • Power Rating at 25°C: 7W
  • Suitable thermistor Sensor
Suitable Sensor:
You can use (100kohm  NTC Thermistor) with the this controller board
  • Thermistor Type: NTC
  • Resistance: 100kohm
  • Beta Value (K): 3974K
  • Operating Temperature Range: -60°C to +300°C
  • Thermistor Case Style: Axial Leaded
Technical Details
Dimensions0mm x 0mm x 0mm
WeightG.W 68g
BatteryExclude
ECCNNot Available
HSCODE9025900090
Reviews
Questions and Answers
SUBMIT
    View History
    SKU 102990086
    $59.00
    DISCONTINUED
    $59.00/ 1pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
