Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Integrated Design Provides Integrated design of brushless motor, reducer, magnetic absolute encoder and controller
  • 12-bit absolute encoder Includes 12-bit magnetic absolute encoder, supporting arbitrary angle setting as the zero-position and multi-turn angle control
  • Angle memory Ensures position data is retained after power-off.
  • Smooth motion curve Trapezoidal acceleration and deceleration control profile generates a smoothed motion curve
  • Comprehensive protection features Provides comprehensive protection functions including thermal shutdown, voltage protection, stall detection, and current/power limitation
Product
Fashionstar HP6-U15H-M Servo
Voltage
9V ~ 12.6V
Operating Temperature
-10℃~60℃
Mechanical Dimension
31.5mm x 21mm x 27.6mm
Communication Interface
UART/TTL Half-Duplex
Baud rate
9,600bps~1Mbps
Angle Range
±180° (Single-turn Angle Control Mode)
±368,640° (Multi-turn Angle Control Mode)
Resolution
0.088°
Max Stall Torque
1.47N·m (15kg-cm)
Max Continuous Torque
0.59N·m (6kg-cm)
Rated Speed
80rpm(0.125sec@60°)
Hardware Overview
Application
Robotics
Documents
Certification
HSCODE8501109990
USHSCODE8501106080
UPC
EUHSCODE8501109390
COOCHINA
x1
Servo Horn
x1
PM M1.6*5mm Screw
x10
PM M3*12mm Screw
x4
3*6*0.5mm Gasket
x4
M3 Lock Nut
x4
250mm Servo Cable(Servo-Servo)
x1
200mm Servo Cable (Servo-Adapter Board)
x1
SKU 114090074
Fashionstar HP6-U15H-M Servo is a 12V 15kg single-shaft serial bus servo with bracket that integrates brushless motor, reducer, magnetic absolute encoder and controller. With a 257:1 reduction ratio, the servo's stall torque comes at 15 kg. cm and the rated torque at 1.8kg. cm. Designed for versatility, it is suited for use in industrial automation, robotics, and low-torque drive applications. It comes with ample code examples that can help accelerate deployment and integration.
USD$42.00
You may also add
