Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Integrated Design Provides Integrated design of brushless motor, reducer, magnetic absolute encoder and controller
  • 12-bit absolute encoder Includes 12-bit magnetic absolute encoder, supporting arbitrary angle setting as the zero-position and multi-turn angle control
  • Angle memory Ensures position data is retained after power-off.
  • Smooth motion curve Trapezoidal acceleration and deceleration control profile generates a smoothed motion curve
  • Comprehensive protection features Provides comprehensive protection functions including thermal shutdown, voltage protection, stall detection, and current/power limitation
Voltage
9V ~ 12.6V
Operating Temperature
-10℃~60℃
Mechanical Dimension
40mm x 40mm x 20mm
Communication Interface
UART/TTL Half-Duplex
Baud rate
9,600bps~1Mbps
Resolution
0.176°
Operating Mode
Single-turn Angle Control Mode
Multi-turn Angle Control Mode
Damping Mode
Max Stall Torque
2.45N·m (25kg-cm)
Max Continuous Torque
0.88N·m (9kg-cm)
Rated Speed
18rpm(0.556sec@60°)
Hardware Overview
Application
Robotic Arm
Documents
Certification
HSCODE8501310000
USHSCODE8501106080
UPC
EUHSCODE8501109390
COO
HA8-U25H-M Servo
x1
Horn
x1
PM M3*6mm Screw
x1
PM M2*4.5mm Screw
x8
PM M3*14mm Screw
x4
M3 Lock Nut
x4
Mounting Spacer
x2
200mm 3-pin Cable (PH2.0×2)
x1
Fashionstar HA8-U25H-M servo
SKU 100094864
Fashionstar HA8-U15H-M Servo is a 12V 25kg single-shaft serial bus servo with bracket that integrates brushless motor, reducer, magnetic absolute encoder and controller. With a 273:1 reduction ratio, the servo's stall torque comes at 25 kg. cm and the rated torque at 3.4kg. cm. Designed for versatility, it is suited for use in industrial automation, robotics, and low-torque drive applications. It comes with ample code examples that can help accelerate deployment and integration.
USD$18.00
You may also add
