Product | Fashionstar RP6-U15H-M Servo |
Voltage | 9V ~ 12.6V |
Operating Temperature | -10℃~60℃
Mechanical Dimension | 31.5mm x 21mm x 27.6mm |
Communication Interface | UART/TTL Half-Duplex |
Baud rate | 9,600bps~1Mbps |
Angle Range | ±180° (Single-turn Angle Control Mode) ±368,640° (Multi-turn Angle Control Mode) |
Resolution | 0.088° |
Max Stall Torque | 1.47N·m (15kg-cm) |
Max Continuous Torque | 0.59N·m (6kg-cm) |
Rated Speed | 80rpm(0.125sec@60°) |
Robotics
| HSCODE | 8501109990 |
| USHSCODE | 8501106080 |
| UPC | |
| EUHSCODE | 8501109390 |
| COO | CHINA |
Fashionstar RP6-U15H-M Servo | x1 |
Servo Horn | x1 |
Assistant Servo Horn | x1 |
PM M1.6*5mm Screw | x19 |
250mm Servo Cable(Servo-Servo) | x1 |
200mm Servo Cable (Servo-Adapter Board) | x1 |
Fashionstar RP6-U15H-M Servo is a 12V 15kg dual-shaft serial bus servo that integrates brushless motor, reducer, magnetic absolute encoder and controller. With a 257:1 reduction ratio, the servo's stall torque comes at 15 kg. cm and the rated torque at 1.8kg. cm. Designed for versatility, it is suited for use in industrial automation, robotics, and low-torque drive applications. It comes with ample code examples that can help accelerate deployment and integration.
