Grove - Alcohol Sensor
SKU 101020044
7.90
10 Available
$7.90/ 1pcs+
$7.11/ 10pcs+
Grove - Alcohol Sensor is a complete alcohol sensor module for Arduino or Seeeduino. It is built with MQ303A semiconductor alcohol sensor. It has good sensitivity and fast response to alcohol. It is suitable for making Breathalyzer. This Grove implements all the necessary circuitry for MQ303A like power conditioning and heater power supply. This sensor outputs a voltage inversely proportional to the alcohol concentration in air.
Technical Details
Dimensions40mm x 20mm x 12mm
WeightG.W 11g
BatteryExclude
Power requirements 5 VDC @ ~120 mA (heater on)
Detection Gas Alcohol
Concentration 20-1000ppm Alcohol
Interface 1 TTL compatible input (SEL), 1 TTL compatible output (DAT)
Heater Voltage 0.9V ± 0.1V AC or DC
Heater Current 120 ± 20mA
Grove - Alcohol Sensor1
Grove Cable1
ECCNEAR99
HSCODE9027900000
Certification
RoHSCompliant
Reviews
Questions and Answers
SUBMIT
0
To do the 48 hours preheat, do i just connect the sensor, the base shield and an arduino board together and plug them into a computer/power source? Or do i have to do something with the code first?
on Mar 28,2018
Reply upvote ()
Hi there~ Please plug this sensor into baseshield,plug the baseshild into the arduino,and connect the the arduino to you computer via USB cable, then you need to update the code and keep the code running for 48 hours. For more detail,please refer to our wiki. Regards ================================================================ http://wiki.seeedstudio.com/Grove-Alcohol_Sensor/
on Mar 29,2018 09:32 AM
Reply upvote ()
Reply
0
I have bought the Grove Shield for Micro:bit, and I also purchased some other sensor, say Alcohol sensor and HCHO sensor. Do they need a library for implement in microbit?
on Dec 12,2017
Reply upvote ()
Hi there~Normarlly, if a sensor does not need a library in Arduino,then it does not need a library in micro:bit either.So you can use HCHO and Alcohol with micro:bit.Regards
on Dec 13,2017 09:51 AM
Reply upvote ()
Reply
    View History
    SKU 101020044
    $7.90
    10 Available
    $7.90/ 1pcs+
    $7.11/ 10pcs+
    • Description
    • Technical Details
    • Learn
    • Reviews
    • Questions and Answers
    SUBMIT
