Grove - Encoder
Grove - Encoder
SKU 111020001
4.90
50+ Available
$4.90/ 1pcs+
$4.41/ 10pcs+
$4.17/ 20pcs+
$3.92/ 50pcs+
This module is an incremental rotary encoder. It encodes the rotation signal from the axis and output the signal by electronic pulse. The Grove – Encoder is one of the Grove series and has a standard Grove interface.
When you need to add a rotary knob to your project, for example a volume knob for a speaker, a selection panel or a digital input, this will be your first choice.
Note
It is able to generate another signal when it’s being pressed down. However due to the limitation of the number of Grove signal cable, the module is made without output of this signal.
  • Incremental encoder
  • Grove Interface.
  • 360 degree rotary
  • Voltage: 4.5V~5.5V
  • Current: 10mA~30mA
  • Dimension: 20*20mm
  • Net Weight: 12g
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Technical Details
Dimensions130mm x 90mm x 22mm
WeightG.W 12g
BatteryExclude
Grove - Encoder1
ECCNEAR99
HSCODE8538900000
Certification
RoHSCompliant
Reviews
Questions and Answers
SUBMIT
0
FWIW, this does not currently work correctly on the Wio devices. Seeed's existing driver doesn't distinguish between turning direction, so you can only receive a pulse for every incremental rotation, no matter which direction you're turning. Thus, in
on Oct 19,2016
Reply upvote ()
Hi Vinoth kumar.The amplitude of the pulse signal is dependent on the flow rate.
on Oct 20,2016 10:45 AM
Reply upvote ()
Reply
0
Is it possible to somehow unlock the possibilities of the push function?
on Oct 19,2016
Reply upvote ()
Hi,Nathan Berzai.You can drop a line to order@seeedstudio.com,maybe our custom service will help you,and you can offer your demand.
on Oct 20,2016 10:44 AM
Reply upvote ()
Reply
0
This is screaming to be made as an I2C interface device so you can get that push-button in place. Is the push signal on an easily-tapped pad? Can't tell from the images.
on Oct 19,2016
Reply upvote ()
Hi,Nathan Berzai.Now we aim at water flowing,but a drip from a sink may not be detected.Perhaps we will make a more sensitive one in the future.
Reply upvote ()
Reply
    View History
    Grove - Encoder
    SKU 111020001
    $4.90
    50+ Available
    $4.90/ 1pcs+
    $4.41/ 10pcs+
    $4.17/ 20pcs+
    $3.92/ 50pcs+
    • Description
    • Technical Details
    • Learn
    • Reviews
    • Questions and Answers
    SUBMIT
