seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Grove - Gas Sensor(MQ5)
      SKU 101020056
      $7.90
      10 Available
      $7.90/1pcs+
      $7.50/10pcs+
      $7.25/20pcs+
      $7.00/50pcs+
      ADD TO CART
      How to choose a gas sensor ?
      The Grove - Gas Sensor(MQ5) module is useful for gas leakage detecting(in home and industry). It can detect LPG, natural gas, town gas and so on. Based on its fast response time. measurements can be taken as soon as possible. Also the sensitivity can be adjusted by the potentiometer.
      For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
      NoteHot-swapping the grove may lead to IC burnout, please turn off the power of main board before swapping grove.
      DOCUMENTS
      More information about gas sensor, please refer to this manual.
      Technical Details
      Dimensions130mm x 90mm x 20mm
      WeightG.W 16g
      BatteryExclude
      Grove - Gas Sensor(MQ5)1
      Reviews
      Questions and Answers
      SUBMIT
      0
      I found that the sensor pins are identical from other sensors. Can I replace or remove the sensor from one driver to another driver? Can I buy a CO2 sensor from the 3rd party and wire it on the Grove Gas driver?
      Thanks.
      on Oct 19,2016
      Replyupvote ()
      <p>Hey , if the circuit is the same, then it will be possible. We don't know what sensor you will buy and how you use that. The warning is at own risk. But happy hacking :)</p>
      on Oct 20,2016 10:47 AM
      Replyupvote ()
      Reply
      0
      Hi. I am trying to build a gas detection system using the arduino mega, is The Grove-Gas Sensor(MQ5) compatible with the arduino? If it is, how do I send the signal from the sensor to the arduino? (Meaning what type of cable, servo cable or other type)
      on Oct 19,2016
      Replyupvote ()
      <p>Yes, it is compatible with Arduino , but you need to get Grove-Base Shield(<a href="http://www.seeedstudio.com/depot/grove-base-shield-p-754.html?cPath=132_134)" rel="nofollow">http://www.seeedstudio.com/dep...</a> and Grove cable(<a href="http://www.s
      on Oct 20,2016 10:44 AM
      Replyupvote ()
      Reply
      0
      Will it detect ozone? If so what range?
      on Oct 19,2016
      Replyupvote ()
      <p>Hello Ivan, it could not be used to detect ozone. This sensor only support to detect some nature gas, you could refer to the datasheet (<a href="http://seeedstudio.com/wiki/images/c/ce/MQ-5.pdf)" rel="nofollow">http://seeedstudio.com/wiki/im...</a> for
      on Oct 20,2016 10:43 AM
      Replyupvote ()
      <p>Hi Kent, thank you for your feedback. We are only the distributor for this product, it is designed by Dangerous team, it will be appreciated if you could send your inquiry to this forum(<a href="http://dangerousprototypes.com/forum/)" rel="nofollow">ht
      Replyupvote ()
      Reply
      0
      Could you please let me know if this is suitable for smoke detection or should I use Twig gas sensor MQ2 - and to be used with an Arduino
      on Oct 19,2016
      Replyupvote ()
      <p>Twig - Gas Sensor MQ2 is more for smoke detection.</p>
      on Oct 20,2016 10:40 AM
      Replyupvote ()
      <p>Hello Mohammed, very sorry that we are only distribute this product and we do not know much about its technology. Hence , please send your inquire to the designer(<a href="http://dangerousprototypes.com/forum/)" rel="nofollow">http://dangerousprototype
      Replyupvote ()
      Reply
        View History
        SKU 101020056
        $7.90
        10 Available
        ADD TO CART
        $7.90/1pcs+
        $7.50/10pcs+
        $7.25/20pcs+
        $7.00/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
