seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Grove - Loudness Sensor
      SKU 101020063
      $5.90
      10 Available
      $5.90/1pcs+
      $5.31/10pcs+
      $5.01/20pcs+
      $4.72/50pcs+
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      The Grove - Loudness Sensor is designed to detect the loudness of environmental sound. Based on amplifier LM2904 and a built-in microphone, it amplifies and filters the high frequency signal that received from the microphone, and outputs a positive envelop. This will make for Arduino's signal acquisition. The output value depends on the level of sound input. In order to avoid unnecessary signal disturbances, input signal will go through two times  filtering inside the module. Lastly, there is a screw potentiometer that enables manual adjustments to the output gain.
      • Grove compatible interface
      • Wide supply voltage range
      • Built-in signal filtering
      • Gain adjustable via screw potentiometer
      For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
      Technical Details
      Dimensions24mm x 20mm x 9.8mm
      WeightG.W 9g
      BatteryExclude
      Voltage3.5~10 VDC
      Working Frequency50~2000 Hz
      Sensitivity-48~66 dB
      Signal-to-noise Ratio>58 dB
      Output Signal rangeAnalog Signal (0-1023)
      Grove - Loudness Sensor1
      Reviews
      Questions and Answers
      SUBMIT
      0
      Can anyone tell me what "U4" is in the circuit diagram? It's a small 4-pin SMD component on the under-side is all that I know. A voltage regulator? Anyone have a part number? Thanks.
      on Jan 24,2018
      Replyupvote ()
      Hi~ It is LMV358D (LMV358), Regards
      on Jan 24,2018 11:59 AM
      Replyupvote ()
      Thank you for your fast response. I notice that LMV358 is an 8-pin device and that the picture above shows this component missing in the finished device. Do you know whether this is needed and if so why there are only 4 pads? Thanks
      on Jan 24,2018 20:01 PM
      Replyupvote ()
      Reply
      0
      Hello, how do I interpret the values read from the board? For example, I seem to get values ranging from 130 to 160 in an ordinary environment. When I blow, I get values of 400/500. When I clap, the value goes down to 60/50. Can you help with this?
      on Dec 13,2016
      Replyupvote ()
      Thanks for your prompt response. I know it is a stupid question to ask - but, is there a correlation between the voltage level on the SIG pin to the "db" level of the input?
      on Dec 16,2016 00:04 AM
      Replyupvote ()
      Reply
      0
      Does it come with a cable?
      on Oct 19,2016
      Replyupvote ()
      <p>Yes, it comes with the cable</p>
      on Oct 20,2016 10:49 AM
      Replyupvote ()
      Reply
      0
      is it possible to use it with 3.3V power? I am using a MSP430 micro controller that operates on 3.3 V. If not, is there another board that works with 3.3 V?
      on Oct 19,2016
      Replyupvote ()
      <p>Hi Bari,</p><p>Yes,the Loudness Sensor can work well under 3.3V power.</p>
      Replyupvote ()
      Reply
      0
      I bought this sensor.
      And I could not know the principle of this sensor.
      PLEASE SEND ME THE CIRCUIT OF THIS SENSOR.
      AND PLEASE WRITE THE CAPACITANCE AND RESISTANCE.
      rud920@hanmail.net
      Please help me~T.T
      on Oct 19,2016
      Replyupvote ()
      <p>Hi, you can download the eagle circuits here: <a href="http://www.seeedstudio.com/wiki/Grove_-_Loudness_Sensor#Resource" rel="nofollow">http://www.seeedstudio.com/wik...</a> </p>
      on Oct 20,2016 10:48 AM
      Replyupvote ()
      <p>I could not open the file ".brd".<br>how can i open '.brd' file? <br>i tried to open that file through 'Allegro Free Physical Viewer 15.7"<br>but, i could not open with this message " The database is corrupted. It may have been copied from a different
      Replyupvote ()
      <p>Please try this software "Eagle" to open the schematics files.</p>
      Replyupvote ()
      Reply
      0
      What is the difference between the Grove loudness sensor and the grove sound sensor?
      Which would be better at detecting loud low sounds? (e.g. neighbor's truck)
      on Oct 19,2016
      Replyupvote ()
      <p>The Working Frequency is different,the working Frequency of loudness sensor only can up to 2K, but sound sensor can up to 16K.</p>
      on Oct 20,2016 10:47 AM
      Replyupvote ()
      Reply
        View History
        SKU 101020063
        $5.90
        10 Available
        Maximum Qty: 5
        $5.90/1pcs+
        $5.31/10pcs+
        $5.01/20pcs+
        $4.72/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Learn
        • Reviews
        • Questions and Answers
        • Related
        • View History
        SUBMIT
        Invalid email address.
