Grove - Universal 4 pin connector
SKU 110990030
1.50
50+ Available
$1.50/ 1pcs+
$1.35/ 10pcs+
$1.27/ 20pcs+
$1.20/ 50pcs+
Grove - Universal 4 Pin connector is the white 4-pin buckled connector used on Stem, Twigs and the Grove cables, the pin spacing is 2mm. There are 10 connectors per bag, Users can use them to DIY.
Documents
Please visit OPL page for more info about this product. It will be appreciated if you can help us improve the documents, add more demo code or tutorials. For technical support, please post your questions to our forum
Technical Details
Dimensions0mm x 0mm x 0mm
WeightG.W 4g
BatteryExclude
ECCNERA99
HSCODE8536901100
Certification
RoHSCompliant
Reviews
Questions and Answers
SUBMIT
0
Several grove compatible boards use this connector with a SMD footprint. Where is this available? It would be nice to have, as an addition to the 2 available variants.
on Dec 01,2016
Reply upvote ()
Hello, I also have the demand for SMT connectors for an own special board with Grove connectors. Do you know any supplier for them can you offer them yourself? Regards, Siegfried
on Jan 08,2017 23:00 PM
Reply upvote ()
Reply
1
Can you please ask your supply vendor for these connectors to make them available on aliexpress? For those of us designing our own boards, this is a preferred method. I certainly don't want to buy these 10 at a time separate from the rest of my part orders. it also precludes me from using assembly services for PCB board houses.
on Oct 18,2017
Reply upvote ()
For the same reason I do not think I can use Grove systems. I have no way to specify to the board manufacturer (even if it is seeed studio!!!) what the part is, and I could never use another board assembler to make Grove compatible hardware. I need a real part number and ideally a STP model in order to think of making anything that uses Grove.
on May 02,2018 00:44 AM
Reply upvote ()
Reply
0
May someone give the spacing and width information for the pins ? Like spacing between pins and pins width plz. Thank you already for the effort.
on Oct 18,2017
Reply upvote ()
hi, The spacing between pins is 2.0mm,The length is 10mm, the height is 8mm and the width is 5mm.Have fun!
on Feb 07,2018 10:56 AM
Reply upvote ()
Reply
0
I ordered the TE Connectivity 1735446-4 as recommended by Steve Chang on 2011-12-12, but the thermoplastic shape of the shrouded male header is incompatible with the actual Grove connectors. Can you provide the correct manufacturer part number for bulk
on Oct 19,2016
Reply upvote ()
Hi Akeem, we are sorry for the inconvenience to you. The TE Connectivity 1735446-4 may just similar to the Grove connector. We buy this product from our local electronic manufacturer. If you need a larger quantity for this product, please send email to
on Oct 20,2016 10:47 AM
Reply upvote ()
Reply
0
Do you have a 3D Model file for this connector, so I can import it into my PCB Layout software? STEP, STL, ...
on Oct 19,2016
Reply upvote ()
Sorry, we do not have a 3D Modle for this connector.
on Oct 20,2016 10:43 AM
Reply upvote ()
Reply
0
Still waiting for both Grove connectors to be in stock.
on Oct 19,2016
Reply upvote ()
Hi,you can keep in touch with our custom service(jianye.huang@seeedstudio.com),he'll help you.
Reply upvote ()
Reply
0
Why can't you keep these parts in stock?
on Oct 19,2016
Reply upvote ()
Hi,Dear.We will have this product in stock after our holiday.
Reply upvote ()
Reply
0
Hi, I'd like to make grove cables from normal wires, because I need very large distances (it's for home automation). Do you sell the cable ends ?Thanks.
on Oct 19,2016
Reply upvote ()
Sorry, we don't have the plan to see the cable ends recently. You might need to buy the grove cables back and revise by yourself.
on Oct 20,2016 10:41 AM
Reply upvote ()
Reply
    View History
    SKU 110990030
    $1.50
    50+ Available
    $1.50/ 1pcs+
    $1.35/ 10pcs+
    $1.27/ 20pcs+
    $1.20/ 50pcs+
    • Description
    • Bundle sales
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
