Product Details
Wiki & Learn
Reviews
Download PDF
The Grove - OLED Display 1.12'' V2 is a little elegant screen that can add a screen interaction feature to your Arduino. With the onboard 4-pin I2C Grove connector, you can plug-and-play with the screen and Arduino in no time.
This is the second version of our Grove - OLED Display 1,12'', it uses I2C interface. Compared with the Grove - OLED Display 1.12'', the Grove - OLED Display 1.12'' V2 is a monochrome display which means do not support 16 grayscale anymore. However, the removal of the gray level support increases the pixel speed by factor 4. In other words, the gray level support was exchanged for a huge performance boost. Additionally, the max I2C bus speed was increased from 100KHz (old 96x96) to 200KHz (V2). So all in all the new 128x128 display has an 8 times higher pixel speed, making it a super fast high-resolution display compared to the older one.
Special thanks to Oliver for contributing this description to us.
Certification
HSCODE8531200000
USHSCODE8531200020
UPC841454120582
EUHSCODE8531202090
COOCHINA
Technical Details
Dimensions40mm x40mm x12mm
WeightG.W 15g
BatteryExclude
Dot Matrix128 x 128 pixels
ColorGrayscale Display (16 Gray shades)
InterfaceI2C
Working Voltage3.3v/5v
Supports both Normal and Inverse Color Display
Grove - OLED Display 1.12'' V21
Grove Cable1
SKU 101020452
USD$3.90
