Intel® Edison Breakout Kit
SKU 102100001
Free Express Shipping on Orders over $200!
$72.50
QUANTITY:
STYLE:
DESCRIPTION
This Kit includes a tiny Edison fits nicely onto a breakout board - sort of like a tiny IoT sparrow into a very small nest, so you can expose the native 1.8 V I/O of the Edison.
And it is for non-Arduino users. This breakout board has a minimalistic set of features and is slightly larger than the Edison module.
Dimensions: 61mm x 29mm x 12mm
FEATURES
• Uses a 22nm Intel® SoC that includes a dual core, dual threaded Intel® Atom™ CPU at 500MHz and a 32-bit Intel® Quark™ microcontroller at 100 MHz.  It supports 40 GPIOs and includes 1GB LPDDR3, 4 GB EMMC, and dual-band WiFi and BTLE on a module slightly larger than a postage stamp.
• The Intel Edison module will initially support development with Arduino* and C/C++, followed by Node.JS, Python, RTOS, and Visual Programming support in the near future.
• It includes a device-to-device and device-to-cloud connectivity framework to enable cross-device communication and a cloud-based, multi-tenant, time-series analytics service.
• The breakout board has exposes native 1.8V I/O of edison module. And 0.1'' grid I/O array of through-hole solder points. USB OTG with USB Micro Type-AB connector, USB OTG power switch. Battery Charge, USB to device UART bridge with USB Micro Type-B connector,  DC power supply jack (7V – 15V DC input).
SPECIFICATION
Physica
Form factor            Board with 70-pin connector
Dimensions            61mm x 29mm x 12mm
Operating temperature            0 to 40 degC
Connector            Hirose DF40 Series
(1.5mm, 2.0mm, or  3.0mm stack height)
Memory
Max Memory size            4GB
Memory type            DDR3, Nand Flash
Physical add. Ext.            32-bit
# of  DIMMs            0
ECC Memory supported:             NO
External Interfaces
Total of 40 GPIOs which can be configured as:
SD Card            1 Interface
UART            2 Controllers
I2C            2 Controllers
SPI            1 Controller with 2 chip selects
I2S            1 Controller
GPIO            Additional 12 (with 4 capable of PWM)
USB 2.0            1 OTG Controller
Clock Output            32 KHz, 19.2 MHz
Major Edison Components
SoC            22nm Intel SoC includes: a dual core, dual threaded Intel Atom CPU at 500MHz, and a 32-bit Intel Quark microcontroller at 100 MHz
RAM            1 GB LPDDR3 POP memory
Flash Storage            4 GB eMMC
WiFi            Broadcom 43340 802.11 a/b/g/n
Dual-band (2.4 and 5 GHz)
On board antenna or external antenna SKU configurations
Bluetooth            BT 4.0
Power
Input            3.3V – 4.5V
Output            100ma @3.3V and 100ma @ 1.8V
Power            Standby (No radios): 13mW
Standby (BT 4.0): 21.5mW
Standby (WiFi): 35 mW
Firmware + Software
CPU OS            Yocto Linux v1.6
Development Environments            Arduino IDE
Eclipse supporting: C, C++ & Python
Intel XDK supporting: Node.JS & HTML5
MCU OS            RTOS
Development Environments            MCU SDK and IDE
DOCUMENTS
RELATED PRODUCTS
You Might Also Need
$72.50
  • $72.50 /each 1 pcs
  • $69.50 /each 10 pcs
QUANTITY:
STYLE:
SUBMIT
