Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Switch selection: The 115VAC or 230VAC input can be switched by the red switch on the side.
  • Reliable Quality:The casing is exquisite and the height is only 30mm. It can withstand a 5G vibration test.
  • Fan efficiency:A silent fan with high wind power, capable of withstanding long-term continuous operation. The fan will be activated when RTH3 is greater than 50℃; and it will be deactivated when RTH3 is less than or equal to 40℃.
  • Multiple protections:short circuit protection, overload protection, overvoltage protection, overcurrent protection, overheating protection.
  • Surge resistance:Capable of withstanding a 300VAC surge input for 5 seconds.
  • High efficiency in power conversion:The LRS series has an electric power conversion efficiency ranging from 90% to 88%, and the heat loss it generates is half that of a 80% energy-efficient power supply.
  • Ultra-low no-load loss:The LRS series features no-load losses ranging from 0.2W to 0.75W, meeting energy-saving requirements.
Product
LRS-350-12 12V 29A Power Supply
Operating Temperature
-25℃~70℃
Input
90 ~ 132VAC / 180 ~ 264VAC(by switch)
240 ~ 370VDC(switch on 230VAC)
47 ~ 63Hz 6.8A/115VAC 3.4A/230VAC
Output
12V 29A 348W
Connection type
Full bridge
Dimension
215*115*30mm(L*W*H)
Weight
760g
Hardware Overview
Application
  • Industrial automation machinery
  • Industrial control system
  • Mechanical and electrical equipment
  • Electronic instruments, equipments or apparatus
Certification
HSCODE8504401400
USHSCODE8504409510
UPC
EUHSCODE8504400000
COOCHINA
x1
fixed trestles
x4
screws
x4
Terminal cover plate
x1
LRS-350-12 12V 29A Power Supply(Only for StarAi Arm Cello)
SKU 100051368
LRS-350-12 12V 29A Power Supply is the switching power supply for Fashionstar StarAi Arm Cello. Its DC output and AC input connectors are screw terminals.
USD$45.00
You may also add
