MilCandy - the Easiest Grove Controller
  • MilCandy - the Easiest Grove Controller
SKU 102990023
The MilCandy could be the easiest controller to manipulate your physical world
$5.90$26.90
6 Available
Qty:
This field is required
ADD TO CART
The MilCandy could be the easiest controller to manipulate your physical world. It's an all-in-one design with cost and convenience in mind. It enables accomplishing simple AI tasks by plug-in sensor, actuator, and setting the triggering pattern via a few button clicks. Its Arduino based open source firmware could be updated for more complex logic.
Milcandy just compatible with Grove - Universal 4 Pin 20cm Cable (5 PCs Pack). If need other length of Grove cable, you should cut the buckle down.
  • Ships with Set-Trigger Firmware
  • Arduino compatible
  • Grove interface for sensors and actuators
  • On-board LED indicator and light sensor
  • All-in-one design with LiPo battery and enclosure
  • Cost efficient
  • Tiny and light
We‘ve prepared a video and a diagram for your instant understanding of MilCandy. Want more, or would like to get an educational material? Check the MilCandy Applications Guide after them!
  Module name  Parameter to measure
  Grove- Button  On/Off
  Grove-Electricity Sensor   Electricity
  Grove-Gas Sensor(MQ2&MQ5)  Gas Quality
  Grove-Light Sensor  Light
  Grove- Magnetic Switch  Magnetic
  Grove- Moisture Sensor  Moisture
  Grove- PIR Motion Sensor  PIR Motion
  Grove- Rotary Angle Sensor  Rotary Angle
  Grove- Tilt Switch  Object Position
  Grove- Sound Sensor  Sound
  Grove- Temperature Sensor  Temperature
  Grove- Touch Sensor  Human touch
  Grove- Water Sensor  Water
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Documents
Please visit our wiki page for more info about this product. It will be appreciated if  you can help us improve the documents, add more demo code or tutorials. For technical support, please post your questions to our forum
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Questions and Answers
SUBMIT
0
I want to use PIR Motion sensor with relay switch to detect people. If the sensor level above certain value, I want it to switch on relay. But if the level below that value, I want to switch off relay after several minutes, not immediate response. Is i
on Oct 19,2016
Replyupvote ()
You can open the cap and download your program to Milcandy via UartSBee(http://www.seeedstudio.com/dep.... And the board you need to select is “Atmega168”
on Oct 20,2016 10:48 AM
Replyupvote ()
Reply
0
Hi, I was wondering if the Milcandy can (when running an Arduino program) use the USB port as a serial interface with the standard Arduino serial library. Can anyone tell me?
on Oct 19,2016
Replyupvote ()
On my account page, I've uploaded the file again.
Please ignore the mail.
on Oct 20,2016 10:45 AM
Replyupvote ()
I'm sorry it can't do that. It can be only regarded as a charger port. Because DP and DM have no connection.
on Oct 20,2016 10:47 AM
Replyupvote ()
Reply
0
Hi All,
I need a standalone box to use the Grove Emitter to continuously transmit a simple Infrared signal.
Do you think can I use the MilCandy to connect a Grove Emitter and transmit the signal or do you suggest something else?
Thank y
on Oct 19,2016
Replyupvote ()
Do I need to put an IF interface? in this case, which one to command the Grove emitter (plugged into the then output) to send an Infrared signal continously?
on Oct 20,2016 10:44 AM
Replyupvote ()
Reply
0
Using a word, words, or sounds to chang out put stage.
on Oct 19,2016
Replyupvote ()
?What is your question?
on Oct 20,2016 10:42 AM
Replyupvote ()
Reply
See More
View History
Recommendations
SUBMIT
Invalid email address.
