Please complete required options
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
This solution uses a core Gateway Server for protocol interoperability, with optional HMI Devices for local display and control.
Step 1: Select a Gateway Server
The gateway connects, converts, and processes data. Key factors for selection:
Criteria
Interfaces
Ensure required ports (RS485/232, Ethernet, etc.). Use expanders if needed.
Environment
Choose based on conditions (e.g., temperature, dust). Fanless designs are more robust for harsh environments.
Performance
Ensure adequate CPU/RAM for your applications (e.g., Node-RED). Select devices with AI capabilities (TOPS) if needed.
Display
Integrated screens (HMI) simplify deployment. Screenless units require a separate HMI.
Step 2: Select an HMI Device (Optional)
For screenless gateways or multi-location control, select an HMI device based on:
Criteria
Interaction
Choose between display-only (e-paper) or touch control (reTerminal, Indicator).
Screen Size
Select based on data complexity and viewing distance.
Development
Pick a device compatible with your tools (LVGL, Python, Home Assistant) for easier development.
Application
SenseCraft provides a complete set of tools adapted to the hardware, from device configuration and data reading to AI model deployment, making it easy for you to build your own solutions.
Low-code programming for event-driven applications : Node-RED is a powerful low-code programming tool for wiring together hardware devices, APIs and online services. You can use its extensive library of nodes (including Modbus, OPCUA, MQTT, etc.) to quickly build data acquisition, processing, and control flows in a graphical way.
Home Assistant is a leading open-source home automation platform that prioritizes local control and privacy. It can automatically discover and integrate thousands of smart home and IoT devices, providing you with a unified management and automation center.
Multi-Protocol Interoperability
SKU E2025081502
Unify your building's devices across different protocols like Modbus, BACnet, and OPC UA. Our smart gateway solution connects HVAC, lighting, and meters, breaking down data silos. Achieve centralized monitoring, control, and energy savings with our out-of-the-box system.4. Content
USD$0.00
Please select at least one option
