seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Prototyping system for the micro:bit
      SKU 114991413
      $22.95
      4 Available
      $22.95/1pcs+
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      This prototyping system for the micro:bit is a great way to start making circuits and making experiments. This gives access to the pins on the bottom of the micro:bit.
      Please note: micro:bit is NOT included.
      This prototyping system uses the specially designed edge connector breakout board for micro:bit. The micro:bit pins are broken out to a row of solderable pads. The SCL and SDA pins are separated at the edge of the board providing easy identification. The PCB includes a prototyping area with 3V, 0V and unconnected rows that can be soldered to. This allows easy connection of switches, sensors and any pull-up or pull-down resistors etc. as required.
      This prototyping system is used in conjunction with a small prototype breadboard. This makes it easy to connect additional components using the included jumper wires. No soldering required.
      Note: This kit requires assembly.
      Features:
      • No soldering is required
      • Breaks out 21 pins from the micro:bit using the pre-built edge connector breakout board for micro:bit
      • Small prototype breadboard included so you can use additional components
      • Run your own custom code from your micro:bit to interact with external components
      Technical Details
      Dimensions160mm x 95mm x 35mm
      WeightG.W 140g    N.W 138g
      BatteryExclude
      small prototype breadboard1
      jumper wires male to male10
      jumper wires male to female10
      Perspex mounting plate1
      edge connector breakout board for micro:bit - pre-built1
      Reviews
      Questions and Answers
      SUBMIT
        View History
        SKU 114991413
        $22.95
        4 Available
        Maximum Qty: 5
        $22.95/1pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
