Raspberry Pi High-Precision AD/DA Board
Rating:
100% of 100
There's no AD/DA function on the Raspberry Pi GPIO interface, this may trouble you in the Pi development. However, it won't be a problem anymore. The High-Precision AD/DA Board allows you to add high-precision AD/DA functions to the Raspberry Pi.
$29.99
In stock
  • 10+: $28.49
  • 20+: $26.99
  • More
  • 50+: $25.49
  • Less
Raspberry Pi 1 Model A+
Raspberry Pi 1 Model B+
Raspberry Pi 2 Model B
Raspberry Pi 3 Model B
  • Onboard ADS1256, 8ch 24bit high-precision ADC (4ch differential input), 30ksps sampling rate
  • Onboard DAC8532, 2ch 16bit high-precision DAC
  • Onboard input interface via pinheaders, for connecting analog signal, the pinout is compatible with Waveshare sensor interface standard, easy to connect various analog sensor modules
  • Onboard input/output interface via screw terminals, for connecting analog/digital signal
  • Features AD/DA detect circuit, easy for signal demonstration
1. Raspberry Pi GPIO interface: for connecting with the Pi
2. AD/DA input/output: screw terminals
3. AD input: pinheaders, the pinout is compatible with Waveshare sensor interface standard, easy to connect various analog sensor modules
4. 7.68M crystal
5. LM285-2.5: provides reference voltage for the ADC chip
6. Photo resistor
7. LED output indicator
8. 10K potentiometer
9. DAC8532: 16bit high-precision DAC, 2ch
10. Power indicator
11. ADS1256: 24bit high-precision ADC, 8ch (4ch differential input)
12. ADC testing jumper
13. DAC testing jumper
14. Power selection jumper
15. ADC reference ground configuration: when AD single inputted, the AINCOM is reference terminal, can be connected to GND or external reference voltage
SymbolPinDescription
3.3V1, 17Power supply (3.3V)
5V2, 4Power supply (5V)
NC3, 5, 7, 8, 10, 18, 22, 24, 26, 27, 28, 29, 32, 36, 38, 40NC
GND6, 9, 14, 20, 25, 30, 34, 39Ground
DRDY11ADS1256 data ready output, low active
RESET12ADS1256 reset input
PDWN13ADS1256 sync/power off input, low active
CS015
ADS1256 chip select, low active
CS116
DAC8532 chip select, low active
DIN19SPI data input
DOUT21SPI data output
SCK23SPI clock
GPIO31, 33, 35, 37extend to sensor interface
Raspberry Pi High-Precision AD/DA Board*1
Dimensions 110mm x80mm x30mm
Weight G.W 37g
Battery Exclude
ECCN ERA99
HSCODE 8517709000
USHSCODE 8517700000
This is the wiki page for this product, which will show you how to use the product, as well as details about the software and hardware.
Customer Reviews
  1.
    Rating
    100%
    Review by
    Posted on
  2.
    Rating
    100%
    Great Product This is a great product: fast, high bit-rate, high throughput. signal quality...
    Review by
    Posted on
Product Faqs
Sort by
  • Question by: admin on 2018-12-18 02:19:42
    Hi, there~ the voltage range is about 0~5V, and the different range will effect the precision, you can check the datasheet of ads1256, Regards!
    Answer by: admin on 2018-12-18 02:19:42
