Note:
What is MeshCore? MeshCore User Guide
| Network protocol | LoRa(Supports 863-928 MHz range), Bluetooth v5.1 |
| Temperature | Range: -20 to 60℃;Accuracy: ± 1℃ (min ±0.5℃, max ±1℃)Resolution: 0.1℃ |
| Light | 0 to 100% (0% is dark, 100% is brightest) |
| 3-Axis Accelerometer | Built-in motion sensor. Function availability depends on firmware support. |
| LED and Buzzer | 1*LED and 1* buzzer to indicate status |
| Button | 1* Button to operate |
| Antenna | Internal (GNSS/LoRa/Wi-Fi/BLE) |
| Communication Distance | 2 to 5km (depending on antenna, installation, and environments) |
| IP Rating | IP65 |
| Dimensions | 85 * 55 * 6.5 mm |
| Device Weight | 32g |
| Operating Temperature | -20℃ to +60℃ |
| Operating Humidity | 5% - 95% (No condensation) |
| Certification | CE /FCC/RoHs/Telec |
| Battey Capacity | Rechargeable lithium battery, 700mAh |
| Battery Life Monitoring | Battery level available through compatible MeshCore clients |
| Charge Cable(Adapter not included) | USB magnetic charging cable, 1 meter |
| Power Input Voltage | 4.7 to 5.5V DC |
| Charging Temperature Limit | 0 to +45℃ |
Connect with nearby nodes, participate in public channels, and share geographic locations — in all areas without cellular coverage.
| HSCODE | 8526919090 |
| USHSCODE | 8526910040 |
| UPC | |
| EUHSCODE | 8517180000 |
| COO | CHINA |
| Tracker T1000-E | x1 |
| USB Cable (adapter not included) | x1 |
This product is not available for sale, shipment, or resale in Mainland China due to regional restrictions.
It is a compact MeshCore device designed for off-grid communication and location sharing.
About the size of a credit card, it can be easily carried or attached to gear for outdoor use. Powered by Semtech's LR1110 LoRa transceiver (863–928 MHz), Nordic's nRF52840 processor, and the MediaTek AG3335 GNSS module, it enables reliable long-range LoRa communication and location updates within MeshCore networks.
