The SenseCAP MeshTracker X1 is designed for people who need reliable off-grid communication and location sharing beyond cellular networks—whether exploring the outdoors, attending large events, or preparing for emergencies. Its compact, genuinely portable form factor and rugged IP66 protection bring MeshCore connectivity to everyday carry and real-world field use.
MeshTracker X1 combines dual-band L1 + L5 GNSS with a built-in barometer for outdoor positioning and pressure sensing. Dual-band GNSS can improve positioning in challenging signal conditions; actual accuracy depends on satellite visibility and the environment. Location sharing and sensor data availability depend on the MeshCore firmware and app version.
MeshTracker X1 has achieved up to 8 km of communication range in open line-of-sight testing at 915 MHz. This is a reference test result, not a guaranteed range for every MeshCore setup. Actual range depends on terrain, obstructions, antenna orientation, radio settings, and interference. Configure frequency and transmit power for local regulations.
The Semtech LR2021 transceiver provides the radio hardware for MeshCore LoRa communication. Receiver sensitivity depends on the selected bandwidth and spreading factor. Its FLRC capability is a separate radio mode: the chip-level maximum of 2.6 Mbps is not the MeshCore LoRa data rate. Voice, image, and high-speed data features require compatible firmware and client support and are not promised by the hardware specification alone.
Slim and lightweight, the MeshTracker X1 is designed for everyday carry and outdoor adventures. Wear it on a lanyard, attach it to a backpack, secure it to a bike bag, or simply slip it into your pocket for effortless MeshCore connectivity wherever you go.
MeshTracker X1 includes a vibration motor and buzzer for tactile and audible feedback. Available alerts and notification settings depend on the installed MeshCore firmware and client version.
The IP66-rated enclosure provides protection against dust ingress and powerful water jets for outdoor use. IP66 does not cover immersion. Keep the USB-C port dry before charging.
Standard USB-C interface for charging, firmware updates, and debugging, designed for rugged outdoor use and everyday convenience.
The built-in 1100 mAh rechargeable battery supports portable off-grid use. Actual runtime varies with firmware, GNSS activity, Bluetooth connection, radio settings, and message traffic.
| Main Controller | Nordic nRF52840 | |
| LoRa | Semtech LR2021 | Frequency Range: 863–928 MHz MAX TX Power: 22 dBm |
| Wireless | Bluetooth (v5.0) | |
| LED | 1 × RGB | |
| Buzzer | 1 × buzzer to indicate status | |
| Button | 1 × button to operate | |
| Vibration | 1 × DRV2605L | |
| Sensor | Air Pressure | Range: 300–1100 hPa Accuracy: ±0.06 hPa Resolution: 0.06 Pa |
| Temperature (Read from barometer) | Range: −40–85°C Resolution: 0.0006°C | |
| * IMU + Magnetometer | ||
| Battery | Battery Capacity | Rechargeable high-voltage battery, 1100 mAh |
| Battery Life Monitoring | Periodic uplink battery level | |
| Charging Protocol | ||
| Power Input | Device: 5 V, 0.55 A Battery: 4.4 V, 0.22A | |
| Fully-charged cut-off voltage | 4.37V | |
| Charging Temperature Limit | 5 to +45℃ | |
| Antenna | Internal (GNSS/863-928MHz LoRa/Bluetooth) | |
| Communication Distance | Up to 8 km | |
| IP Rating | ||
| Dimensions | 90 × 57 × 8 mm | |
| Device Weight | 45 g | |
| Operating Temperature | −20 to 60℃ | |
| Certification | CE/FCC/RoHS/TELEC | |
IMU and magnetometer are not included in this model. Specifications for future X1 variants will be announced separately.
From crowded festivals to remote mountain trails, MeshTracker X1 helps you stay connected, share locations, and coordinate with your group—even when cellular networks are unavailable or overloaded.
Stay Connected Beyond Cell Coverage
Whether hiking through forests, exploring mountain trails, or backpacking into remote areas, MeshTracker X1 lets your group share locations and communicate when mobile coverage disappears.
Track, Coordinate, and Ride Together
Share location updates and coordinate meetups while cycling or skiing. Update frequency and message delivery depend on GNSS reception, firmware settings, and available radio coverage.
Keep in Touch with Your Group
Exchange messages and location updates during festivals, outdoor events, and races without relying on cellular service. Communication requires compatible MeshCore devices with matching radio settings and sufficient direct or repeater coverage.
Communication When It Matters Most
MeshTracker X1 can provide an additional way to exchange messages and location updates when cellular service is unavailable. Delivery depends on power and radio coverage; it is not a guaranteed emergency alert or rescue service.
| HSCODE | 8517629990 |
| USHSCODE | 8517620090 |
| UPC | |
| EUHSCODE | 8517180000 |
| COO | CHINA |
MeshTracker X1 | x1 |
20 cm USB-C Cable | x1 |
Leather Keychain | x1 |
A card-sized MeshCore companion for off-grid messaging and location sharing. MeshTracker X1 combines dual-band L1 + L5 GNSS, a Semtech LR2021 LoRa transceiver covering 863–928 MHz, an IP66-rated enclosure, and a 1100 mAh rechargeable battery with USB-C charging. Pair it with a compatible MeshCore app over Bluetooth to exchange messages beyond cellular coverage.
