Wifi Shield (Fi250)
  • Wifi Shield (Fi250)
Wifi Shield (Fi250)
SKU 113030004
Please consider Wifi Shield (Fi250) V1
$59.90
DISCONTINUED
Please consider Wifi Shield (Fi250) V1.1 as alternative product
Wifi shield (Fi250)is a economic internet solution with Arduino. The Wi-Fi module support IEEE 802.11b/g/n mode, maximum speed up to 65Mbit/s. Wifi shield (Fi250) combine on board antenna; it’s easy to build you project in a small box. The module reserve a UFL connector, you can use an extra antenna to improve the signal range. There is a key on the board, just push one time to change wifi shield as AP mode. The module have a computer interface software, you can control and upgrade the module via USB-UART convertor. The wifi shield contain a Micro SD card socket, it’s like a recorder when wifi shield working as TCP, UDP server.
Specification:
  • ModuleWIZnet FI250
  • Operating Voltage 5V or 3.3V (Auto select)
  • Current 300mA (maximum)
  • Single band2.4GHz IEEE 802.11b/g/n
  • AntennaOn board PCB antenna (reserver UFL connector)
  • Memory1MB Flash Memory, 128KB SRAM, 1MB Serial Flash
  • InterfaceUART(default)/SPI(upgrade firmware)
  • Dimensions69.0x53.5x23.5 mm
Related Part Number:
Compatibility:
  • Arduino
  • Seeeduino
  • Grove
Application:
wifi shield (fi250)
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Questions and Answers
SUBMIT
0
What is the difference between this board and this one
http://www.seeedstudio.com/dep...
on Oct 19,2016
Replyupvote ()
Thanks for your attention, we would take it into consideration.
on Oct 20,2016 10:48 AM
Replyupvote ()
Reply
0
How do I access the SD? wich chip select do i have to set?
on Oct 19,2016
Replyupvote ()
You can drop a line to order@seeedstudio.com if you have problem of order. Thanks.
Replyupvote ()
Reply
0
I can't make it start in boot mode even thou boot jumper is set correctly. OTA Update server from wiznet seems to be not working any more. Is there actually a way to update the firmware of this shield?
on Oct 19,2016
Replyupvote ()
Pins VR1 and VR2 come preset. Please DON'T change the default configuration. And the dust sensor don't need any calibration.
Replyupvote ()
Reply
0
We bought 12 of the wi-fi shields but can't get them to work with the Uno R3. We've followed the instructions exactly like on the wiki FAQ http://www.seeedstudio.com/wik.
on Oct 19,2016
Replyupvote ()
Now the frequency is 30s. High rate testing may get a inaccurate data.
on Oct 20,2016 10:47 AM
Replyupvote ()
Please make sure the first three steps are done correctly. WIFI_RX -> D0 and WIFI_TX ->D1
Replyupvote ()
I have one of the 12 units that Warrick bought. I can confirm that I have followed steps 1-3 correctly (assuming that step 2 means to upload Blink to the Arduino, rather than the shield). While it is connected to D0 and D1, I can communicate with it wi
Replyupvote ()
Please send this problem to our technical support email: tickets@seeed.uservoice.com You will get a good solution there.
Replyupvote ()
Reply
0
My base shield was working fine, but when I connect this WiFi Fi250 appears the following error message:"avrdude: stk500_getsync(): not in sync: resp=0x00". When I remove the Fi250 WiFi shield, the error message disapears! Whats could be?
on Oct 19,2016
Replyupvote ()
The unit of Detectable range of concentration is pcs/liter. And it is a qualitative test, so you may not transfer it to the concentration in ug/m3.
Replyupvote ()
Reply
0
Hi, this product seems really sweet. Are there any limitations in using Stalker with both base and wifi shields stacked up on top each other? Wont their pin requirements conflict in this scenario?
on Oct 19,2016
Replyupvote ()
Hi,Simón Genestra Amengual.you only put the this sensor exposed to the air.and it can get the data 30s per once.with a happy day~
on Oct 20,2016 10:46 AM
Replyupvote ()
yes, you can use them together. But please pay attention to the 'USB5V' port, it could provide 5v only if you plug a external power to the stalker, such as UartSBee.
Replyupvote ()
Reply
0
I set it in AP mode but my Mac wants a password and thinks it uses WPA2
on Oct 19,2016
Replyupvote ()
This is the solution:"123456789"see: http://wizwiki.net/wiki/doku.p..., so seeedstudio, update your quick start guide.
Replyupvote ()
Reply
0
Is it possible to connect grove sensors directly without base shield?
on Oct 19,2016
Replyupvote ()
yes, you can. All our shield serial products have two Grove connectors.
Replyupvote ()
Reply
0
Good to see new product rolling out. Is there schematic available?
on Oct 19,2016
Replyupvote ()
Dear Calvani Paolo.You may not use digital pin 11 instead of ditital pin 8.If you want to use digital pin 11 ,you need add some program , it seems more difficult.
on Oct 20,2016 10:43 AM
Replyupvote ()
yes, the schematic is available ,i'm sorry we forgot add it to the wiki, we would update it later.Thanks for your attention.
Replyupvote ()
Reply
See More
View History
Best-sellers
SUBMIT
Invalid email address.
