Xadow - Adaptor
  • Xadow - Adaptor
  • Xadow - Adaptor
  • Xadow - Adaptor
  • Xadow - Adaptor
Xadow - Adaptor
SKU 103040006
Xadow Grove Adaptor is a device that converts Grove interface to Xadow Interface to compatible with Xadow System
Free Express Shipping on Orders over $200!
$14.90
OUT OF STOCK
This item is not available at the moment
Get notified when it's back in stock
$14.90/1pcs+
$13.41/10pcs+
$12.67/20pcs+
$11.92/50pcs+
Xadow Grove Adaptor is a device that converts Grove interface to Xadow Interface to compatible with Xadow System. It can achieve this function: analog signal from two analog Grove interface will output by Xadow I2C bus through ADC. The signal from Grove I2C Interface will directly lead to Xadow I2C bus without conversion. The A/D conversion based on ADCC121C021, a 12-bit precision ADC, create high precision.
Note: This module is not compatible with any other Xadow version 2 or RePhone modules.
SPECIFICATION
  •  - Work Voltage: 3.3V
  •  - A/D Resolution:12 bit
  •  - Sample Rate: 188.9 ksps
  •  - I2C address variable
Compatibility issue: Not all of Grove parts can be used at the same time. For example: Grove - Chainable RGB LED can't be used with other Grove analog sensor at the same time due to the reuse of wires. We suggest use I2C/analog Grove parts together.
Xadow is a though small but perfectly formed Arduino(TM) compatible board series containing several modules. It's a kit extremely suitable for space-sensitive projects such as wearable devices & arts designs, which have higher request on size, weight and flexible cascade connection.
You can find more modules here.
DOCUMENTS
Please visit our wiki page for more info about this product. It will be appreciated if you can help us improve the documents, add more demo code or tutorials. For technical support, please post your questions to our forum.
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Reviews
See More
Questions and Answers
SUBMIT
See More
View History
Best-sellers
SUBMIT
Enjoy $15 off on your first order over $50 or more. Discounted items included!
Invalid email address.
