the AI Hardware Partner
Toggle Nav
Loading...
Raspberry Pi Wide Angle Camera Module - Fisheye Lens, 160 AoV, adjustable camera, 4 screw holes mounted, suitable for large landscape surveillance
Rating:
100 % of 100
Raspberry Pi Wide Angle Camera Module benefits from Fisheye Lens to achieve 160 angle of view, which supports all the versions of Raspberry Pi. Its distance, resolution, and other parameters are adjustable and there are 4 screw holes on the module, a popular option for large spaces, widely used in large landscape surveillance.
$28.99
In stock
  • 10+: $23.19
Also Add: $0.00
Feature
  • Compatible Raspberry Pi Series Camera: 5 megapixel OV5647 sensor equipped, supports Raspberry Pi 2 / 3B / 3B+ / 4 / Zero
  • Wider Angle of View: Benefits from Fisheye Lens to achieve 160 angle of view
  • Adjustable Camera Module: Adjustable distance, resolution(1080p at the best), white balance, brightness and sharpness
  • On-module 4 Screw Holes: Convenient for attachment to surveil a large landscape
Raspberry Pi Wide Angle Camera Module benefits from Fisheye Lens to achieve 160 angle of view, whereas normal cameras are typically 72 degrees. This camera supports all the versions of Raspberry Pi. Its distance, resolution, and other parameters are adjustable and there are 4 screw holes on the module, a popular option for large spaces, widely used in large landscape surveillance.
The Fisheye Len, as the main part of this camera module, is producing visual distortion, projecting a characteristic convex appearance, displayed on the hemispherical screens. That is, it offers a much wider angle of view capturing function to the Raspberry Pi compared to the Rectilinear Len.
The camera module provides adjustable functions where you can control the Raspberry Pi to change its focus distance, resolution, white balance, brightness and sharpness. Meanwhile, there are 4 screw holes on the module. Utilizing these fine features, this camera module can be placed on the top of the wall to surveil any unusual activity or movement on the property.
If you are not looking for large landscape photography, and want to capture something specific or highly detailed, we recommend other cameras, for example:
Application
  • Monitor in large space
  • Large landscape surveillance
  • Image capture for wide view AI applications
Details
Camera Lens
Fisheye Lens
Camera Module
Sensor best resolution
1920*1080
CCD size
1/4inch
Aperture (F)
2.35
Focal Length
Adjustable
Angle of View (diagonal)
160 degree
Screw Holes
4 screw holes;
provides 3.3 power output;
supports connecting fill flash LED
External Fan
Power connector for fan (For reference, please check this fan. The power connector fits)
Dimensions
25x24mm
Raspberry Pi Wide Angle Camera Module x1
Q&A
What should I care when I connect it with Raspberry Pi?
The connectors of the DSI interface (for display) and the CSI interface (for camera) look the same, please take care of it when you connect the camera.
How can I adjust the focal length?
You can refer to the wiki here to adjust the camera, which also provides additional functions about the camera.
Dimensions 110mm x50mm x20mm
Weight G.W 17g
Battery Exclude
HSCODE 8525801302
USHSCODE 8525501000
EUHSCODE 8517600000
COO CHINA
CE 1
EU DoC 1
RoHS 1
  1. Documentation
    100%
    Product Quality
    100%
    from order view
    Delivered in a timely manner for onforwarding to our customer for use.
    By
  2. Documentation
    100%
    Product Quality
    100%
    from order view
    By
  3. Product Quality
    100%
    By
  4. Product Quality
    100%
    By
4 Item(s)
Show per page
