Wio Link Deluxe Kit
Rating:
80% of 100
Well-chosen modules for Wio Link Rich grove modules and cables Cost-effective
$119.00
Out of stock
  • 10+: $107.10
  • 20+: $101.15
  • More
  • 50+: $95.20
  • Less
This kit is a full package of lots frequently required functional modules for someone who intends to do some real project or make a prototype. It contains sensors(mainly), switching-function modules, servo motors, LED strip and a speaker. The most amazing part of this kit is the Wio Link development board which can be utilized for various devices: without a bit programming skill required. All the actions you want your modules performed and the flashing-code operation to Wio Link could be completed with taps in a mobile app. And you can send instructions to your devices over the internet at anywhere. Wio Link will be a perfect utility to make things around smarter for everyone. Now let us do something real!
  • Full package of all general required functional modules
  • Grove port interfaced, more practical function and less work
  • Completely easy to make things around you smarter and add fun to daily life
  • Cost-effective
attention icon
Warning
The Wio IFTTT function is EOL. But Wio APP is available. You can use the API from Wio APP to read sensor status and control the actuator.
Dimensions 200mm x130mm x70mm
Weight G.W 363g
Battery Exclude
Grove - Button 1
Grove - Relay 1
Grove - Moisture Sensor 1
Grove - Temp&Humi Sensor 1
Grove - Digital Light Sensor 1
Grove - Rotary Angle Sensor 1
Grove - Protoshield 1
Grove - Magnetic Switch 1
Grove - 3-Axis Digital Accelerometer(1.5g) 1
Grove - IR Distance Interrupt 1
Grove - Barometer Sensor (BMP180) 1
Grove - Air quality sensor v1.3 1
Grove - Gesture 1
Grove - I2C Hub 1
Grove - Speaker 1
Grove - WS2812 Waterproof LED Strip - 30 LEDs 1 meter 1
Micro USB Cable - 48cm 1
Grove - Servo 1
Wio Link 2
ECCN 5A002.a.1
HSCODE 9023009000
DIY a fully automatic monitor Boss Key
A website to see the environment data around you
Make your simple outdoor temp. device
Make your temp. device use wio link! The outdoor wio link check the temp. And the indoor wio link get indoor temp. and display two different temp.
Traffic light indicates Travis CI compiled results
How to feed your pets when you're not home
No More Missed Calls from Your Honey
Wio Link Deluxe Kit
Wiki of Wio Link Deluxe Kit
Customer Reviews
  1.
    Rating
    80%
    Review by
    Posted on
Product Faqs
Sort by
