CPT-C5 power converter 12V&24V switch to 5V
Rating:
100% of 100
Conversion efficiency of 96%. Epoxy Glue, waterproof, shock, moisture, suitable for harsh environments. Short circuit protection, over current, over temperature protection, when the fault is solve then back to work.
$8.50
In stock
  • 10+: $7.65
  • 20+: $7.23
CPT-C5 is a power converter module output 5V. Low heat, adopt synchronous rectification technology (5A long-term without any additional cooling measures).
  • Conversion efficiency of 96%.
  • Epoxy Glue, waterproof, shock, moisture, suitable for harsh environments.
  • Short circuit protection, over current, over temperature protection, when the fault is solve then back to work.
  • Ultra-small size 66 * 60 * 23mm(L * W * H, without cable), about 100 grams.
Applications Ideas
  • Solar power
  • Taxi advertising screen
  • LCD TV
  • Monitoring systems
Dimensions 0mm x0mm x0mm
Weight G.W 108g
Battery Exclude
Input voltage DC12/24V (8-35V)
Output voltage 5V
Output Power 25W
Soft-start time 500mS
Operating temperature Industrial (- 40 °C to +85°C )
Full load temperature 50 °C
Load Regulation ± 1%
Voltage regulation ± 2%
Dynamic response speed 5% 200uS
Input reverse polarity protection No, if necessary, add a series diode at input port
Cable length 12cm
Cable Size 18AWG
CPT-C5 power converter 12V&24V switch to 5V 1
ECCN ERA99
HSCODE 8504339000
USHSCODE 8504312000
UPC 841454116325
Customer Reviews
  1.
    Rating
    100%
    Review by
    Posted on
Product Faqs
Sort by
  • What is the wire AWG used?
    Question by: Kenneth Carpenter on 2019-04-15 15:11:37
    Hi there, the cable size is 18awg and length is 12cm. thanks.
    Answer by: admin on 2019-04-28 09:49:29
