PL2303 USB to Serial (TTL) Module&Adapter
Rating:
87% of 100
It's a small USB to TTL serial tool, using the PL2303 chip
$1.95
Out of stock
  • 10+: $1.76
  • 20+: $1.66
  • More
  • 50+: $1.56
  • Less
It's a small USB to TTL serial tool, using the PL2303 chip. You can use it to connect some serial device to your PC via USB port.
Features:
  • Compatible with 32-bit & 64-bit Windows, Mac OS 8 to OS X, Linux and Android!
  • To test the unit use the shunt to connect TX and RX (loopback test)
  • 3.3V and 5.0V outputs are available to power your project directly from the adapter.
Part List:
1 x USB to TTL module
Dimensions 0mm x0mm x0mm
Weight G.W 6g
Battery Exclude
ECCN ERA99
HSCODE 8517709000
USHSCODE 8517700000
UPC 841454115519
Customer Reviews
  1.
    Rating
    100%
    Review by
    Posted on
  2.
    Rating
    100%
    Review by
    Posted on
  3.
    Rating
    60%
    Good, but needs drivers I didn't know about it, I thought this would work as the FTDI or other Serial adapters on my MAC that just work. This needs an extra driver.
    Other than that, it works good.
    Review by
    Posted on
Product Faqs
Sort by
