the AI Hardware Partner
Toggle Nav
Loading...
Grove - Infrared Emitter
The Infrared Emitter is used to transmit infrared signals through an infrared LED, while there is an Infrared receiver to get the signals on the other side
$4.30
In stock
  • 10+: $3.00
The Infrared Emitter is used to transmit infrared signals through an infrared LED, while there is an Infrared receiver to get the signals on the other side . An infrared LED is like any other LED, with its color centered around 940nm. We can use the emitter not only to transmit data or commands, but also to emulate remotes to control your home appliance using an Arduino. The Infrared Emitter can transmit signals reliable up to 10 meters. Beyond 10 meters, the receiver may not get the signals.
Now the The Infrared Emitter v1.2 is available, we optimized the circuit design to increase the transmission distance.
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Dimensions 20mm x20mm x18mm
Weight G.W 9g
Battery Exclude
Grove - Infrared Emitter 1
HSCODE 9031900090
USHSCODE 9018200080
UPC 841454108146
EUHSCODE 9013101000
COO CHINA
EU DoC 1
RoHS 1
UK DoC 1
  1. Product Quality
    100%
    Documentation
    100%
    from order view
    OkokOkOkOk
    By
  2. Product Quality
    100%
    Documentation
    100%
    from order view
    Simple and works great
    By
  3. Product Quality
    100%
    Documentation
    100%
    from order view
    This device makes experimenting with IR pretty simple
    By
  4. Product Quality
    100%
    functional IR emitter They work as expected
    By
  5. Product Quality
    80%
    work good good
    By
5 Item(s)
Show per page
