Arduino Ethernet WITHOUT PoE + USB2SERIAL
  • Arduino Ethernet WITHOUT PoE + USB2SERIAL
SKU 113990034
This product is retired, please consider our Seeeduino Ethernet as your alternative choice
$63.20
DISCONTINUED
This product is retired, please consider our Seeeduino Ethernet as your alternative choice.
Arduino Ethernet w/o PoE module
The Arduino Ethernet is a microcontroller board based on the Arduino Uno, and incorporating a WizNet W5100 TCP/IP Embedded Ethernet Controller. It can be programmed like an Uno via a six-pin FTDI -style serial connector. The Arduino USB 2 Serial adapter or any FTDI-style USB-to-serial connector can be used to program it.
A separate power-over-Ethernet (PoE) module can be soldered to the board to provide power from a conventional twisted pair Category 5 Ethernet cable. It is IEEE802.3af compliant, and works with all compliant PoE injectors currently available.
Specifications
  • Microcontroller ATmega328
  • Operating voltage 5V
  • Input voltage (recommended) 7-12V
  • Input voltage (limits) 6-20V
  • Digital I/O pins 14 (of which 4 provide PWM output)
  • Arduino pins reserved
    • 10 to 13 used for SPI
    • 4 used for SD card
    • 2 W5100 interrupt (when bridged)
  • Analog input pins 6
  • DC current per I/O pin 40 mA
  • DC current for 3.3V pin 50 mA
  • Flash memory 32 KB (ATmega328) of which 0.5 KB used by bootloader
  • SRAM 2 KB (ATmega328)
  • EEPROM 1 KB (ATmega328)
  • Clock speed 16 MHz
  • W5100 TCP/IP Embedded Ethernet Controller
  • Power Over Ethernet ready Magnetic Jack
  • Micro SD card, with active voltage translators
USB 2 Serial Converter
This board converts a USB connection into 5 volt TX and RX that you can connect straight to the Arduino Ethernet or any other boards with an FTDI cable-compatible connector.
It features the Atmega8U2 programmed as a USB-to-serial converter, the same chip found on the Arduino Uno. The USB Serial module has an ISCP interface, allowing you to reprogram the chip when placed in DFU mode.
The pinouts on the connector are compatible with a standard FTDI header (as well as the Adafruit and Sparkfun USB-Serial adapters).
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Questions and Answers
SUBMIT
0
thanks for reply to previous question .when i connected this to bees shield and inserted wifi bee on the bees shield.wifi bee is not communicating but power led is glowing .i want to know connecting and working step by step procedure of these three com
on Oct 19,2016
Replyupvote ()
Check if the wifi bee port is conflict with Arduino Ethernet, it has used D10,D11,D12,D13 port.
on Oct 20,2016 10:47 AM
Replyupvote ()
Reply
0
Is this product arduino ethernet W/o poe+usb2serial is compatible with bees shield?
on Oct 19,2016
Replyupvote ()
Yes, they are compatible.
Replyupvote ()
Reply
0
Hi there. I've tried asking on the forums but noone has responded. I need to know if the problem is a faulty device or my not understanding how to use it!
on Oct 19,2016
Replyupvote ()
Hello, what is computer system do you use? If it can not work with your computer, does it has the same problem when it work with any other computer?
on Oct 20,2016 10:43 AM
Replyupvote ()
Reply
0
Hi there. I connect the usb2serial to the Arduino and plug a USB cable from the usb2serial to my computer but nothing appears in lsusb and nothing appears on dmesg. However, the oower LEDs go on on both the converter and the Arduino. Help?
on Oct 19,2016
Replyupvote ()
Thanks for purchasing Arduino Ethernet W/O PoE + USB2SERIAL. We are only the distributor for this product and we do not know much about its technology. Hence, please send your support request to the designer/maker of this product(
I pay an Arduino Ethernet W/O PoE + USB2SERIAL and still it does not come to me to my house.
on Oct 19,2016
Replyupvote ()
Hi Juan, please send your order number to order@seeedstudio.com. we will help you to check the order status.
Replyupvote ()
Reply
0
Is this essentially an Ardueno UNO+Ethernet Sheild on a single board that would run my existing sketches using the ethernet library?
on Oct 19,2016
Replyupvote ()
Yes,it is.This is an Arduino official product.suggest you see more details in http://arduino.cc/en/Guide/Ard...
on Oct 20,2016 10:42 AM
Replyupvote ()
Reply
0
The product notes above say that the module can be bought separately (X000002), but I cannot find it. Do you really sell just the PoE module?
on Oct 19,2016
Replyupvote ()
Sorry, it not sell just PoE module for now.
on Oct 20,2016 10:41 AM
Replyupvote ()
Reply
0
Will you be stocking the Arduino Ethernet board WITH PoE (A000051) or the PoE module anytime soon?
on Oct 19,2016
Replyupvote ()
We have Arduino ETH Shield Rev3 WITH PoE Module in stock now. That integrates theEthenet board and PoE module together. Are you looking for that one?
Replyupvote ()
Reply
See More
View History
Recommendations
SUBMIT
Invalid email address.
