Product Details
Wiki & Learn
Reviews
Download PDF
A BLE (Bluetooth Low Energy) Location Beacon is a small wireless device that transmits Bluetooth signals at regular intervals. These signals can be detected by Bluetooth-enabled devices, such as SenseCAP T1000 Tracker, allowing them to determine their proximity to the beacon, building a location-based solution for indoor positioning, asset tracking and other applications.
LoRaWAN Immediate Emergency Alerts and Responses Solutions
Learn how Bluetooth Location Beacon supports the LoRaWAN Immediate Emergency Alerts and Responses Solutions with precise indoor positioning
  • Bluetooth® LE 5.0
  • Long battery life: Replaceable lithium battery, more than 5 years (0dBm/500ms in default configuration).
  • Long-distance transmission: Up to 120 meters in open areas.
  • High compatibility: Compatible with iOS 7.0+ and Android 4.3+ systems
BLE Indoor Positioning System
GPS has proven its ability to locate outdoors. Now, we also tend to move to indoor positioning, and Bluetooth beacons make indoor precise positioning possible. Combine with SenseCAP T1000 Tracker to build an indoor positioning solution.
Deploy Bluetooth beacons in your target area, the tracker receives the signal sent by the beacon, and the positioning accuracy is at the meter level (2-3 meters). It can realize functions such as asset tracking, route planning, reverse car search, etc., and can be integrated into applets and APPs.
SenseCAP T1000 is a compact LoRaWAN® tracker that utilizes GNSS/Wi-Fi/Bluetooth for precise indoor & outdoor location tracking. It's ideal for a variety of location-based applications.
Chip
nRF52 series
Bluetooth protocol
BLE 5.0
Broadcasting range
120m
Tx Power
-30~+4dBm,default is 0dBm
Adv Interval
100ms~10s,default is 500ms
Battery
Lithium battery, 2400mAh
Working temperature
-30~60°C
Dimension(L*W*H)
Φ50*20.5mm
Dimension
Applications
  • Stores
  • School
  • Offices
  • Conferences
  • Logistics
  • Home Automation
Certification
HSCODE9014800090
USHSCODE9014801000
UPC
EUHSCODE9405413910
COOCHINA
BC01 Indoor Bluetooth Beacon for SenseCAP Tracker
SKU 113991194
A BLE Location Beacon for location-based services, asset tracking, navigation, and other applications, especially for  SenseCAP T1000 Tracker and  SenseCAP T2000 Tracker.
USD$10.80
$12.00
Save $1.20(10%)
