Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Bluetooth® LE 5.0
  • Long battery life: Replaceable Li/SOCl2 battery, more than 5 years (0dBm/500ms in default configuration).
  • Long-distance transmission: Up to 130 meters in open areas.
  • Simple Installation:Pull out the insulating film and it can be pasted and installed, reducing construction costs.
  • UV Protection: Suitable for UV-sterilization lamps and similar scenarios, without altering appearance.
BC03 has a high-gain omni-directional BLE antenna, low-ower consumption, and user interaction:
  • Enhanced Beacon Broadcasting Capability
Optimized BLE advertising stability and RSSI consistency, improving indoor positioning accuracy and robustness in complex environments.
  • Antenna Design
Excellent radiation efficiency and directional consistency, onboard antenna, thus achieving a longer communication range and more stable communication without precise adjustment of the installation direction.
  • Longer Battery Life
Further optimized low-power design. Under the same configuration (0 dBm / 500 ms), BC03 achieves large-scale and long-term deployment.
  • LED Status Added
A blue LED provides intuitive device status feedback during power-on and operation, display the device's power-up and upgrade status.
  • BLE Indoor Positioning System
GPS has proven its ability to locate outdoors. Now, we also tend to move to indoor positioning, and Bluetooth beacons make indoor precise positioning possible. Combine with SenseCAP T1000 Tracker or SenseCAP T2000 Trackerto build an indoor positioning solution.
Deploy Bluetooth beacons in your target area, the tracker receives the signal sent by the beacon, and the positioning accuracy is at the meter level (2-3 meters). It can realize functions such as asset tracking, route planning, reverse car search, etc., and can be integrated into applets and APPs.
SenseCAP T1000 Tracker and SenseCAP T2000 Tracker are LoRaWAN® tracker that utilizes GNSS/Wi-Fi/Bluetooth for precise indoor & outdoor location tracking. It's ideal for a variety of location-based applications.
We provide a open-source Bluetooth indoor positioning system designed to work seamlessly with SenseCAP BLE Beacons and SenseCAP LoRaWAN Trackers.
This solution is fully open-source and customizable, allowing users to build, modify, and integrate their own backend services based on our GitHub repository.
NOTE:
The default UUID of BC03 is different from that of BC01 and BC02. If you are using these models together in the same deployment, please be aware that filtering beacons using two different UUIDs simultaneously is not supported. To ensure compatibility in a mixed environment, please modify the beacons to use the same UUID.
  • General Specification
Parameter
Material
ABS(Anti-UV)
Color
White
IP rate
None
Dimension(L*W*H)
Φ50*20.5mm
Weight
45g(include battery)
Battery
Li/SOCI2 battery, 2400mAh
Chip
nRF52 series
Bluetooth Version
BLE 5.0
Bluetooth Protocol
iBeacon
Sensors
Accelerometer, Optional
LED
1 × Blue LED
APP
SenseCraft APP
Working Temperature
-20~60℃
Battery Life
More than 5 years
  • Default broadcast parameters
Parameters
Default Value
UUID
5EEEDBCA-AC02-43B0-B0CF-C6EB07647825
Major
Assigned from the device MAC address
(lower 2 bytes)
Minor
(upper 2 bytes)
Measured power
-59dBm
Tx Power
-40 ~ +4 dBm, default 0 dBm
Adv Interval
20ms ~ 30s, default 500ms
Password
12345678
Device Name
03
Battery Service
Battery icon display
  • Compatibility information
System
Devices
BLE
BLE 5.0+
iOS 7.0+
iPhone 4S, iPhone 5/5C/5S, iPhone 6/6Plus/6S/6S Plus, iPhone 7/7Plus, iPad mini/mini2/4/Air/Pro, etc.
Android 4.3+
Samsung, XIAOMI, HUAWEI, ONEPLUS, vivo, OPPO, etc.
Hardware Overview
Application
  • Stores
  • School
  • Offices
  • Conferences
  • Logistics
  • Home Automation
Certification
HSCODE9014800090
USHSCODE9014801000
UPC
EUHSCODE9405413910
COOCHINA
Indoor Bluetooth Beacon BC03
x1
3M Sticker(Pre-taped)
x1
Insulating film
x2
SenseCAP BC03 Indoor Bluetooth Beacon for Tracker
SKU 100085893
SenseCAP BC03 Indoor Bluetooth Beacon is a small wireless device that transmits Bluetooth signals at regular intervals. These signals can be detected by Bluetooth-enabled devices, such as SenseCAP T1000 Tracker, SenseCAP T2000 Tracker, allowing them to determine their proximity to the beacon, building a location-based solution for indoor positioning, asset tracking and other applications.
USD$12.00
