seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Grove - 3-Axis Digital Accelerometer(±1.5g)
      SKU 101020039
      $9.90
      21 Available
      $9.90/1pcs+
      $8.91/10pcs+
      $8.41/20pcs+
      $7.92/50pcs+
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      This 3-axis Accelerometer module is based on MMA7660FC with Digital Output I2C. This Module can be used for sensing data changes, product orientation, and gesture detection through an interrupt pin (INT).It is a very low power, low profile capacitive MEMS sensor.
      • Grove compatible interface
      • 3 axis motion/orientation sensing
      • Digital Output (I2C)
      • 10,000 g shock survival
      • RoHS/WEEE lead-free compliant
      • 5VDC input
      Application Ideas
      • Motion Detection of Robot
      • Mobile Phone/ PMP/PDA: Orientation Detection (Portrait/Landscape),Image Stability, Text Scroll, Motion Dialing, Tap to Mute
      For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
      Technical Details
      Dimensions20mm x 20mm x 15mm
      WeightG.W 6g
      BatteryExclude
      Grove - 3-Axis Digital Accelerometer(±1.5g)1
      Grove - Cable1
      Reviews
      Questions and Answers
      SUBMIT
      0
      Hi, I have got this working on a BeagleBone Green. I have created the following JavaScript library for this device: https://github.com/psiphi75/ac...
      on Oct 19,2016
      Replyupvote ()
      <p>We design it to be a logger, it can work with a very low power consumption.</p>
      on Oct 20,2016 10:41 AM
      Replyupvote ()
      Reply
      0
      do you get it works with arduino Due ???
      I don't get it works
      thanks, sorry me english
      on Oct 19,2016
      Replyupvote ()
      <p>The problem was that the "setRtcTime();" line was commented in the RX8025.cpp, so i uncomment the line to set the time and then i comment again to mantaint it.</p><p>I have another question, How can I wake up the Stalker at determinated hour with the R
      Replyupvote ()
      Reply
      0
      Product description Github repo 404s: https://github.com/Seeed-Studi...
      on Oct 19,2016
      Replyupvote ()
      <p>I just tried such a program; and still receive nonsense from the serial monitor. What should I do now?</p>
      on Oct 20,2016 10:40 AM
      Replyupvote ()
      Reply
      0
      Hi
      I'm doing a project where I want to use two Grove - 3-Axis Digital Accelerometer and then calulate which accelerometer gets the highest value. The problem is that they have the same Slave Adresse. Anything I can do?
      on Oct 19,2016
      Replyupvote ()
      <p>Albert, I already tried to connect 5V to the external power connector of the gprs shield (the shield was not stacked on the Stalker). If I provide 5V from the UARTBee, the shield works well ; if I use 5V generated by the booster (transforming 3.7V from
      on Oct 20,2016 10:42 AM
      Replyupvote ()
      <p>The words said on the Data sheet: The device has a factory set I2C slave address which is normally 1001100 (0x4C). Contact the factory to request a different I2C slave address. I'm sorry we don't have method how to change the slave address, maybe you c
      on Oct 20,2016 10:48 AM
      Replyupvote ()
      Reply
      0
      I just got this Acc, and I want to hook it up to my arduino, I too was hoping for a ADXL345 but I have selected this instead. :D
      on Oct 19,2016
      Replyupvote ()
      <p>Why you take off the supercap????</p>
      Replyupvote ()
      <p>Hi,you can use jumper wire to conncet Grove to your Arduino.SDA--A4,SCL--A5,VCC--5V.GND--GND.</p>
      on Oct 20,2016 10:44 AM
      Replyupvote ()
      Reply
      0
      The code in the wiki does not work. What arrived to me also looks different than the module that is pictured. I had the older version, which looks like the pictured one, and it worked fine. I can't get this to work at all.
      What changes need to be
      on Oct 19,2016
      Replyupvote ()
      <p>Ah, it seems that what I got is the ADXL345 version. I didn't realize there were two available. It says "Grove 3-axis Accelerometer" on both of them.</p>
      Replyupvote ()
      Reply
        View History
        SKU 101020039
        $9.90
        21 Available
        Maximum Qty: 5
        $9.90/1pcs+
        $8.91/10pcs+
        $8.41/20pcs+
        $7.92/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Learn
        • Reviews
        • Questions and Answers
        • Related
        • View History
        SUBMIT
        Invalid email address.
