Grove - Infrared Emitter
SKU 101020026
3.90
35 Available
$3.90/ 1pcs+
$3.51/ 10pcs+
$3.31/ 20pcs+
The Infrared Emitter is used to transmit infrared signals through an infrared LED, while there is an Infrared receiver to get the signals on the other side . An infrared LED is like any other LED, with its color centered around 940nm. We can use the emitter not only to transmit data or commands, but also to emulate remotes to control your home appliance using an Arduino. The Infrared Emitter can transmit signals reliable up to 10 meters. Beyond 10 meters, the receiver may not get the signals.
Now the The Infrared Emitter v1.2 is available, we optimized the circuit design to increase the transmission distance.
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Technical Details
Dimensions20mm x 20mm x 18mm
WeightG.W 9g
BatteryExclude
Grove - Infrared Emitter1
ECCN5A991.b
HSCODE9031900090
Certification
RoHSCompliant
Learn
    Reviews
    Questions and Answers
    SUBMIT
    0
    Can it work with odroid c2?
    on Apr 13,2017
    Reply upvote ()
    0
    Is it possible to access this device via the Raspberry Pi? Does it expose itself as a serial device, or is it only accesible via the GPIO library?
    on Oct 19,2016
    Reply upvote ()
    im not from seeed, but i guess 99% this is true:"you can panelize to save the cost, but you need to cut the board by yourself"-that means no extra cutting option, you would have to just fit one board into 5x10, instead of 2, if you want a cut.
    on Oct 20,2016 10:43 AM
    Reply upvote ()
    Reply
    0
    Can it work with Raspberry Pi?
    on Oct 19,2016
    Reply upvote ()
    0
    Does it work with 3V supply and 3V TX logic signal? I want to use with a board which is completely powered with a 3V coin battery.
    on Oct 19,2016
    Reply upvote ()
    Hi.3.3V could supply this work.I think that you use 5V better than 3V~~
    on Oct 20,2016 10:46 AM
    Reply upvote ()
    Reply
    0
    Hi, it's working with UNO, but I am unable to make it work with Arduino Mega ADK or Seeduino ADK. Any suggestions? Thanks in advance
    on Oct 19,2016
    Reply upvote ()
    Hello Muhammad, it is compatible with Mega ADK and Seeeduino ADK. When programming/compiling, you need to change the option of the board in Arduino IDE from Arduino Uno to Arduino ADK.
    on Oct 20,2016 10:47 AM
    Reply upvote ()
    Reply
    0
    Can I Connect It And The Receiver As Well With Out Using The Grove Base Shield ??!
    on Oct 19,2016
    Reply upvote ()
    Hi.Of course yes,our base shield is a transfer borad.You can connect it to Arduino/Seeeduino directly.
    on Oct 20,2016 10:45 AM
    Reply upvote ()
    Reply
    0
    Could be a panel mounted of this and the IR receiver... Can you make it? Thanks!
    on Oct 19,2016
    Reply upvote ()
    Hi Mario.Maybe you could do that, but we have not provided this.
    on Oct 20,2016 10:44 AM
    Reply upvote ()
    Reply
    0
    It's not an option in the customized grove kit?
    on Oct 19,2016
    Reply upvote ()
    Thanks for asking. It's added into the list.
    on Oct 20,2016 10:40 AM
    Reply upvote ()
    Got a status update. Apparently they just shipped it. Thank you.
    on Oct 20,2016 10:42 AM
    Reply upvote ()
    Reply
      View History
      SKU 101020026
      $3.90
      35 Available
      $3.90/ 1pcs+
      $3.51/ 10pcs+
      $3.31/ 20pcs+
      • Related
      • Description
      • Technical Details
      • Learn
      • Reviews
      • Questions and Answers
      SUBMIT
