Grove - SPDT Relay(30A)
  • Grove - SPDT Relay(30A)
SKU 103020012
The SPDT Relay(30A) is a high quality Single Pole Double Throw Relay(SPDT)
Free Express Shipping on Orders over $200!
$9.90
16 Available
Qty:
This field is required
ADD TO CART
$9.90/1pcs+
$8.91/10pcs+
$8.42/20pcs+
$7.92/50pcs+
TheSPDT Relay(30A) is a high quality Single Pole Double Throw Relay(SPDT).The Relay consist of a coil, 1 common terminal, 1 normally closed(NC) terminal and one normally open(NO) terminal. When the coil of the relay is at rest (not energized), the common terminal and the normally closed terminal have continuity. When the coil is energized, the common terminal and the normally open terminal have continuity. This relay's coil is rated up to 5V and the contact is rated up to 30A (@250VAC, 30VDC). Use it to control AC appliances or high current DC devices.
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
NOTE: Please exercise great care and safety precautions when working with mains voltages. If in doubt, contact a professional such as a licensed electrician for help.
KEY FEATURES
  •  - Grove interface compatible
  •  - High Switching Current
  •  - SPDT Relay
  •  - Arduino library ready
  •  - Normally closed relay
TECHNICAL SPECIFICATIONS
  •  - Operating voltage: 4.75V~5.25V
  •  - Operating current: 185mA
  •  - Switching Voltage: 250VAC/30VDC
  •  - Switching Current: 30A
  •  - Pull-In Voltage(Max): 3.75VDC
  •  - Switch on Time(Max): 15ms
  •  - Release Time(Max): 10ms
  •  - Operating Ambient Temperature: -25~70°C
DOCUMENTS
Please visit our WiKi page for more information about this product. For technical support, please post your questions on our Forum.
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Reviews
relay
works well
Nov 15,2016 by
Was this review helpful ?
0
See More
Questions and Answers
SUBMIT
0
hello,, can i control it using arduino?
on Oct 19,2016
Replyupvote ()
0
Does this relay come the 4 pin cable?
on Oct 19,2016
Replyupvote ()
0
Is there a version of this that is normally open?
on Oct 19,2016
Replyupvote ()
0
I would like to know what the amperage rating at 110v 60 Hz AC is.
on Oct 19,2016
Replyupvote ()
The current of 110VAC is the same to current of 250VAC, so the current is 30A.
on Oct 20,2016 10:48 AM
Replyupvote ()
Reply
0
What's the current rating and wire range of the screw terminal
on Oct 19,2016
Replyupvote ()
Hi Sadri, current rating is (@250VAC, 30VDC 30A). and it is recommended that the gauge wire should be a brand-qualified one with assurance of 250VAC/30VDC 30A. Usually there are some intruction on the wire.
on Oct 20,2016 10:47 AM
Replyupvote ()
Reply
See More
Recommended Products
Grove - Touch SensorGrove - Touch Sensor
$3.9
ADD TO CART
Grove - ButtonGrove - Button
$1.9
ADD TO CART
Grove - Tilt SwitchGrove - Tilt Switch
$1.9
ADD TO CART
Grove - I2C Touch SensorGrove - I2C Touch Sensor
$16.9
ADD TO CART
Grove - Button(P)Grove - Button(P)
$1.9
ADD TO CART
Grove - EncoderGrove - Encoder
$4.9
ADD TO CART
View History
Documents
Best-sellers
SUBMIT
Invalid email address.
