Grove - Gas Sensor(MQ2)
SKU 101020055
6.90
2 Available
$6.90/ 1pcs+
The Grove - Gas Sensor(MQ2) module is useful for gas leakage detecting(in home and industry). It can detect LPG, i-butane, methane, alcohol, Hydrogen, somke and so on. Based on its fast response time. measurements can be taken as soon as possible. Also the sensitivity can be adjusted by the potentiometer.
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Note
Hot-swapping the grove may lead to IC burnout, please turn off the power of main board before swapping grove.
Documents
More information about gas sensor, please refer to this manual.
Technical Details
Dimensions130mm x 90mm x 23mm
WeightG.W 16g
BatteryExclude
Grove - Gas Sensor(MQ2)1
Grove cable1
ECCN2B351
HSCODE9027900000
Certification
RoHSCompliant
Reviews
Questions and Answers
SUBMIT
0
What is the maximum length of cabling between the sensor and the controlling computer? I'm putting this on a boat and would like to be able to have the sensor about 10ft (3m) from the computer.
on Apr 25,2018
Reply upvote ()
Hi there~ You can use two Grove- RJ45 adapter and one network cable to connect this sensor to your control board. By this way, it could be 3m or even longer. Regards ================================================================= http://wiki.seeedstudio.com/Grove-RJ45_Adapter/
on Apr 25,2018 09:41 AM
Reply upvote ()
Reply
0
Is this compatible with Wio Link? It doesn't seem to work with mine when configured as a Generic Analog Input device. Keeps the board from powering up.
on Sep 16,2017
Reply upvote ()
Sorry to tell you that, this sensor is not compatible with Wio Link.You can refer to the list of this page. # http://wiki.seeed.cc/Grove-Gas_Sensor-MQ2/#platforms-supported #
on Sep 20,2017 12:58 PM
Reply upvote ()
Reply
0
Is this module compatible with LinkIt ONE?
on Oct 19,2016
Reply upvote ()
Hi! This one's the Bus Blaster, not the Bus Pirate ;) AFAIK, the Bus Blaster is currently on V2.
on Oct 20,2016 10:42 AM
Reply upvote ()
Reply
0
Hola!I am a noob in this field. Can you tell me what is the working range (in m) of MQ2 sensor? Like will it be able to sense smoke from 1m away?
on Oct 19,2016
Reply upvote ()
Dear customer,About this board you can go to Bus Blaster forum http://dangerousprototypes.com... to ask the question.They can help you more then us.
on Oct 20,2016 10:41 AM
Reply upvote ()
Reply
0
Hello! i have a question, how i can get the value in ppm or %? I follow the instructions that the wiki describe, but i have values like:R0= -0.10After i put the R0 value into the other code, and it show me this values:sensor_volt =
on Oct 19,2016
Reply upvote ()
Hi there, sorry there is no cables for this but you can use jumper wire to connect it.
Reply upvote ()
Reply
0
Hello! Can I know if anyone has tried using the board for this sensor with the MQ137 Ammonia sensor? The design is practically almost the same and the pins are similar too.
on Oct 19,2016
Reply upvote ()
Sorry we don't know, better you can kick "Notify Me" when it back it could remind you.
Reply upvote ()
Yes, All Gas sensors have the same schematic.
on Oct 20,2016 10:50 AM
Reply upvote ()
Reply
0
Hi, i want know about the value recollected what is the measured unit
on Oct 19,2016
Reply upvote ()
Hi,You can refer to the document of Gas sensor on the wiki.
on Oct 20,2016 10:47 AM
Reply upvote ()
Reply
0
Hello! Can anyone tell me how I would go about heating up the sensor? I know that I need to apply power to the sensor between 24-48 hours (based on the datasheet), my question is,do I have to apply gas (I was planning on using a lighter for this part)
on Oct 19,2016
Reply upvote ()
Hi Yesenia Lizasuain.Just plugging it to socket,no need other external power.
on Oct 20,2016 10:44 AM
Reply upvote ()
Reply
0
Would I be able to remove the MQ2 on this board and replace it with an MQ8?
on Oct 19,2016
Reply upvote ()
Hi there, We are not sure that MQ8 would work well with the board, but you can try. Because we didn't test the MQ8 before.
Reply upvote ()
Reply
    View History
    SKU 101020055
    $6.90
    2 Available
    $6.90/ 1pcs+
    • Description
    • Technical Details
    • Learn
    • Reviews
    • Questions and Answers
    SUBMIT
