Seeed Studio XIAO nRF52840 - Supports Arduino / CircuitPython- Bluetooth5.0 with Onboard Antenna
- 10+: $8.99
Note
Seeed Studio XIAO nRF52840 is carrying wireless capability for the first time and it supports Bluetooth 5.0, also able to operate with low power consumption. It will be your best microcontroller for Bluetooth applications.
Features
- Versatile Microcontroller: Incorporate the Nordic nRF52840 chip with FPU, operating up to 64 MHz, mounted multiple development ports, supported by Arduino / CircuitPython
- Wireless Capabilities: Implement Bluetooth 5.0, BLE functions with onboard antenna, also provide NFC connectivity
- Elaborate Power Design: Provide ultra-low power consumption as 5 μA in deep sleep mode while supporting lithium battery charge management
- Thumb-sized Design: 21 x 17.5mm, Seeed Studio XIAO series classic form-factor, suitable for wearable devices
Seeed Studio XIAO nRF52840 has an ultra-low power consumption of only 5 μA in the deep sleep mode, the embedded BQ25101 chip supports battery charge management which prolongs its use time. Moreover, Seeed Studio XIAO nRF52840 supports the USB Type-C interface which can supply power and download code. It also has rich On-chip Memory of 1 MB flash and 256 kB RAM, and an Onboard Memory of 2 MB QSPI flash. There are 11 digital i/o that can be used as PWM pins and 6 analog i/o that can be used as ADC pins. It supports UART, IIC, and SPI all three common serial ports. 1 Reset button, 1 3-in-one LED, 1 Charge LED, and 1 Bluetooth antenna are on board, allowing developers to debug their code very easily.
The powerful performance makes it perfect for machine learning applications, and the tiny size allows it to be used in wearable devices and Internet of Things projects, not just for prototypes but the mass production. Furthermore, Seeed Studio XIAO nRF52840 is friendly to the communities for its strong software compatibilities, which support Arduino, Micropython, and CircuitPython. Except for the software, flexible I/O allows it to speak to almost any external device.
Note
You can have access to the Seeed Studio Grove ecosystem by connecting it to the compatible Seeed Studio XIAO expansion board. We have developed more than 400 Grove modules, covering a wide range of applications that can fulfill various needs. For example, you can make a BLE AI-driven Smartwatch Detecting Potential Sun Damage by connecting the Seeed Studio XIAO nRF52840 with an expansion board, and a Grove - UV Sensor. Get started and explore the infinite possibilities of the Seeed Studio XIAO series!
Specification
To better support IoT and TinyML AI projects, there is an advanced version "Seeed Studio XIAO nRF52840 Sense" that carries an extra 6-axis IMU and a PDM microphone.
Item |
Seeed Studio XIAO nRF52840 |
Seeed Studio XIAO nRF52840 Sense |
Processor |
Nordic nRF52840 |
The same as Seeed Studio XIAO nRF52840 |
ARM® Cortex®-M4 with FPU runs up to 64 MHz |
Wireless |
Bluetooth 5.0/NFC |
On-chip Memory |
1 MB flash and 256 kB RAM |
Onboard Memory |
2 MB QSPI flash |
Interface |
1xUART, 1xIIC, 1xSPI, 1xNFC, 1xSWD, |
11xGPIO(PWM), 6xADC |
Sensors |
Onboard PDM digital microphone |
Onboard 6-axis IMU |
Dimensions |
21 x 17.5mm |
Power |
Circuit operating voltage: 3.3V@200mA |
Charging current: 50mA/100mA |
Input voltage (VIN): 5V |
Standby power consumption: <5μA |
Application
- Wearable devices
- Wireless connect
- Embedded machine learning projects
- Perfect for mini Arduino projects
- Tiny Machine Learning application
Hardware Pinout
Attention:
Seeed Studio XIAO nRF52840 | x1 |
Does the XIAO nRF52840 support Zigbee?
Unfortunately, the XIAO nRF52840 doesn't support Zigbee
HSCODE | 8517180050 |
USHSCODE | 8543708800 |
UPC | |
EUHSCODE | 8543709099 |
CE | 1 |
EU DoC | 1 |
FCC | 1 |
RoHS | 1 |
TELEC | 1 |
UK DoC | 1 |
from order viewgood product
from order viewnice product
from order viewperfect for bluetooth 5 mesh
from order viewGood product, very good documentation.
from order viewProduct is excellent, using it for a custom keyboard, and it works flawlessly
