Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Magnetic Connection Design: Precision magnetic alignment ensures proper polarity and secure contact, eliminating reversed connections or unstable charging.
  • 7.62mm 4-Pin Pogo Pin Connector: Matches the SenseCAP T1000-E charging port specifications with standardized pin spacing for reliable power and data transfer.
  • USB Type-C Interface: Universal compatibility with any USB-C power source including computers, wall adapters, and battery banks.
  • Compact Form Factor: Measures 32.31mm × 15.8mm × 11.5mm, ideal for backpacks, vehicles, and field operations.
  • Stable Data Transfer: Supports simultaneous charging and data synchronization for firmware updates and real-time uploads.
Details
Connector Type
Interface Standard
USB Type-C
Input Voltage
5V DC
Output Current
1A
Output Voltage
5V
Charging Technology
Magnetic
Connector Design
Magnetic alignment with reversible polarity detection
Compatible Device
SenseCAP Tracker T1000-E
Dimension
32 mm*11.5 mm*15.8 mm
Hardware Overview
Pin correspondence diagram with T1000-E
①
VCC_IN - Positive terminal of power supply (+5V)
②
USB_D- - Negative line of USB data
③
USB_D+ - Positive line of USB data
④
GND - Ground (power ground)
Application
Users can directly use the most common Type-C cable and this adapter to meet the charging and programming needs of the T1000-E.
Certification
HSCODE8536901100
USHSCODE8536904000
UPC
EUHSCODE8536901000
COOCHINA
SenseCAP T1000-E adapter
x1
SenseCAP Tracker T1000-E Magnetic Charging Data Adapter, 7.62mm 4pin Pogo Pin to Type-C Connector
SKU 100082287
It's a magnetic USB-C charging adapter designed specifically for the Seeed SenseCAP T1000-E GPS tracker, enabling effortless connection and disconnection with stable data transfer. Featuring a 7.62mm 4-pin pogo pin connector, this adapter delivers reliable power delivery and secure charging without connection failures or compatibility issues.
USD$3.50
$4.00
Save $0.50(13%)
You may also add
