Seeed Studio XIAO ESP32S3 Sense - 2.4GHz Wi-Fi, BLE 5.0, OV2640 camera sensor, digital microphone, 8MB PSRAM, 8MB FLASH, battery charge supported, rich Interface, IoT, embedded ML
Seeed Studio XIAO ESP32S3 leverages dual-core ESP32S3 chip, supporting both Wi-Fi and BLE wireless connectivities, which allows battery charge. It integrates built-in camera sensor, digital microphone. It offers 8MB PSRAM, 8MB FLASH, and external SD card slot. All of these make it suitable for embedded ML, like intelligent voice and vision AI.
- 10+: $12.70
Seeed Studio XIAO ESP32S3 Sense integrates a camera sensor, digital microphone, and SD card support. Combining embedded ML computing power and photography capability, this development board can be your great tool to get started with intelligent voice and vision AI.
Feature
- Powerful MCU Board: Incorporate the ESP32S3 32-bit, dual-core, Xtensa processor chip operating up to 240 MHz, mounted multiple development ports, Arduino / MicroPython supported
- Advanced Functionality: Detachable OV2640 camera sensor for 1600*1200 resolution, compatible with OV5640 camera sensor, integrating additional digital microphone
- Great Memory for more Possibilities: Offer 8MB PSRAM and 8MB FLASH, supporting SD card slot for external 32GB FAT memory
- Outstanding RF performance: Support 2.4GHz Wi-Fi and BLE dual wireless communication, support 100m+ remote communication when connected with U.FL antenna
- Thumb-sized Compact Design: 21 x 17.5mm, adopting the classic form factor of XIAO, suitable for space-limited projects like wearable devices
- Pretrained Al model from SenseCraft Al for no-code deployment
Seeed Studio XIAO ESP32S3 Sense is built around a highly-integrated, Xtensa processor ESP32-S3R8 SoC, which supports 2.4GHz WiFi and low-power Bluetooth® BLE 5.0 dual-mode for multiple wireless applications. It has lithium battery charge management capability.
As the advanced version of Seeed Studio XIAO ESP32S3, this board comes with a plug-in OV2640 camera sensor for displaying full 1600*1200 resolution. The base of it is even compatible with OV5640 for supporting up to 2592*1944 resolution. The digital microphone is also carried with the board for voice sensing and audio recognition. SenseCraft AI provides various pre-trained Artificial Intelligence (AI) models and no-code deployment to XIAO ESP32S3 Sense.
With powerful SoC and built-in sensors, this development board has 8MB PSRAM and 8MB FLASH on the chip, an additional SD card slot for supporting up to 32GB FAT memory. These allow the board for more programming space and bring even more possibilities into embedded ML scenarios.
Being a number to the Seeed Studio XIAO family, the board deservedly maintains the classic thumb-sized form-factor design and elegant productization of single-sided components mounting.
Application
- Image processing
- Speech Recognition
- Video Monitoring
- Wearable devices
- Smart Homes
- Health monitoring
- Education
- Low-Power(LP) networking
- Rapid prototyping
Specification
Item |
Processor |
ESP32-S3R8 Xtensa LX7 dual-core,32-bit processor that operates at up to 240 MHZ |
Wireless |
Complete 2.4GHz Wi-Fi subsystem BLE: Bluetooth 5.0, Bluetooth mesh |
Built-in Sensors |
oV2640 camera sensor for 1600*1200 Digital Microphone |
Memory |
On-chip 8M PSRAM & 8MB Flash |
lnterface |
1x UART,1x IIC,1x llS,1x SPl,11xGPIOs (PWM),9x ADC,1x User LED,1x Charge LED 1x Reset button,1x Boot button |
1x UART,1x lIC,1x lIS,1x SPI,11x GPIOs (PWM),9xADC,1x User LED, 1x Charge LED,1x B2B Connector(with 2 additional GPIOs) 1x Reset button, 1x Boot button |
Dimensions |
21 x 17.5mm |
21 x 17.5 x 15mm (with expansion board) |
Power
Input voltage (Type-C): 5V lnput voltage (BAT): 4.2V |
Circuit operating Voltage (ready to operate): - Type-C:5V@19mA - BAT: 3.8V@22mA |
Circuit operating Voltage (ready to operate): -Type-C: 5V@38.3mA - BAT: 3.8V@43.2mA (with expansion board) |
Webcam Web application: - Type-C: - - Photo moment: 5V/341mA - - Photo moment: 3.8V/304mA |
Microphone recording & SD card writing:- Type-C: - - Peak power consumption: 5V/89.6mA - Battery: - - Peak power consumption: 3.8V/108mA |
Charging battery current:100mA |
Low Power Consumption Model (Supply Power: 3.8V) |
Modem-sleep Model:~ 25mA Light-sleep Model: ~ 2 mA Deep Sleep Model:~14 μA |
Modem-sleep Model: ~44mA Light-sleep Model: ~5mA Deep Sleep Model: ~3mA |
Wi-Fi Enabled Power Consumption |
Active Model: ~ 100 mA |
Active Model: ~ 110 mA (with expansion board) |
BLE Enabled Power Consumption |
Active Model: ~85 mA |
Active Model: ~ 102 mA (with expansion board) |
Working Temperature |
-40°C ~65°C |
Note
There are two additional GPIO on the plug-in camera sensor board linking to the microphone. If you want to apply these two external IO, the microphone should not be used at the same time.
Hardware Overview
Pinout
XIAO ESP32S3 |
x1 |
Plug-in camera sensor board |
x1 |
Antenna |
x1 |
Note
The purple shell shown in the picture is not in the part list. You can download the 3D drawings in "Documentations" and print it yourself.
HSCODE | 8517180050 |
USHSCODE | 8543708800 |
UPC | |
EUHSCODE | 8543709099 |
CE | 1 |
EU DoC | 1 |
FCC | 1 |
REACH | 1 |
RoHS | 1 |
TELEC | 1 |
UK DoC | 1 |
from order viewThe Seeed Studio XIAO ESP32S3 Sense is an impressive addition to the XIAO series, offering a powerful combination of connectivity, sensing capabilities, and compactness, making it a standout choice for developers and hobbyists alike who are working on IoT and smart sensor projects.
from order viewWorks perfectly.
from order viewWorks with no issue, neatly delivered
from order viewAs expected, arrived safely. No issues
from order viewWhat a wonderfull board ! Congrats Seeed Studio.
