CodeCraft Is Here: Turn words into working hardware in minutes
CodeCraft is a hardware-focused AI coding assistant that helps you turn natural language ideas into runnable firmware and real device projects in minutes, with cloud compilation and one-click upload.
CodeCraft is officially launched!
To celebrate the launch, register now through July 13 , 2026, and get 1 month of CodeCraft PRO for free.
1.CodeCraft Is Here: From Natural Language to Working Hardware in Minutes
For many makers, students, and educators, the hardest part of a hardware project is not the idea. It is everything that happens before the idea can actually run.
Installing an IDE– Finding the right drivers– Matching libraries to the board– Fixing compile errors– Flashing firmware– Debugging through serial output. In classrooms, this setup process can take away valuable hands-on time. For makers, it can turn a quick prototype into a long night of toolchain troubleshooting.
Today, we are excited to introduce CodeCraft, a hardware-focused AI coding assistant built to take you from an idea to a working device in minutes.
With CodeCraft, you can describe what you want to build in natural language, generate hardware-aware code, compile it in the cloud, and upload firmware to your device with one click.
2.Why CodeCraft?
General AI coding tools are powerful, but most of them stop at code.
Hardware projects need more than code generation. They need the right board configuration, the right pins, the right libraries, the right compile environment, and a reliable path from browser to real device.
That is where CodeCraft comes in.
CodeCraft is designed around the full hardware creation workflow:
  • Describe your idea in plain language
  • Generate code that understands the target board
  • Compile firmware in the cloud
  • Flash it to your device
  • Debug, share, and remix projects with the community
In short: CodeCraft goes beyond writing code. It helps complete the journey from prompt to working hardware.
3.Built for Real Hardware, Not Just Screens
CodeCraft understands hardware context such as processors, I/O, sensors, peripherals, libraries, and board-specific limitations. This helps reduce the gap between “AI-generated code” and “code that actually runs on a device.”
At launch, CodeCraft supports popular Seeed Studio hardware including:
  • Wio Terminal for IoT, interactive displays, sensors, Wi-Fi, Bluetooth, and controls
  • XIAO ESP32S3 Sense for compact edge AI vision projects with camera and microphone
  • Grove Beginner Kit for fast learning with 10 Grove modules on one board
  • Grove ecosystem modules for plug-and-play sensing and interaction
More controllers and sensors are on the way.
4.From Classroom Ideas to Maker Prototypes
CodeCraft is made for anyone who wants to build with hardware faster.
For students, it lowers the barrier between learning an idea and seeing it run on a board.
For educators, it helps classroom projects start in minutes instead of spending half the lesson on setup.
For makers and developers, it makes IoT prototypes, interactive devices, AI vision demos, and creative builds easier to test and iterate.
Try prompts like:
  • Build a Chrome Dino game for Wio Terminal
  • Use a Grove rotary knob to control LED brightness
  • Create an animated eyeball display with XIAO ESP32S3 Sense
  • Build a temperature and humidity monitor with Grove sensors
One prompt can become code, firmware, and a device running on your desk.
5.Part of the Seeed Open Hardware Ecosystem
CodeCraft carries Seeed Studio’s long-standing mission into the AI era: making hardware creation more accessible, practical, and community-driven.
Seeed has always supported makers with open hardware, modular sensors, development boards, and real-world deployment tools. CodeCraft adds a new layer to that ecosystem: an AI agent that understands hardware and helps people move from imagination to implementation faster.
It is not only an AI coding assistant. It is a bridge between ideas, boards, sensors, classrooms, prototypes, and the wider maker community.
6.🎁Launch Offer: Get 1 Month of PRO for Free
To celebrate the launch, we are offering 1 month of CodeCraft PRO for free.
Register now through July 13, 2026, and receive one month of PRO membership to explore more AI credits, code editing, firmware export, and advanced creation capabilities.
Start building with CodeCraft: codecraft.seeed.cc
July 2026
6789101112
13141516171819
20212223242526
2728293031
