FDR Soil Moisture Sensors: How They Work in Modern Agriculture
FDR soil moisture sensors estimate volumetric water content by measuring how soil shifts a high-frequency electromagnetic signal, a dielectric method that needs no sampling, weighing, or drying. This guide covers the physics, the calibration decisions, and where the approach fits in agriculture.
FDR soil moisture sensors read water content from the soil’s dielectric response, so they measure in place without sampling, weighing, or drying. They trade a little reference-grade accuracy for lower power draw and cost per node, which makes dense, unattended networks practical. This guide explains how the measurement works, where salinity and clay set the accuracy limit, and how a field-ready LoRaWAN sensor turns it into usable data.
This article is part of the Weather Sensor Know-How series, which explains how environmental sensors work, what their specifications mean in the field, and where each technology fits.
By Seeed Studio SenseCAP Team · Published on 25 November 2026
FDR soil moisture sensors turn the soil’s dielectric permittivity into volumetric water content (VWC) in place, using low-power high-frequency electronics. That combination is why irrigation networks, greenhouses, and hydrology plots increasingly specify them for continuous, unattended monitoring.[1]
What is an FDR soil moisture sensor?
An FDR soil moisture sensor is a dielectric probe that measures the soil’s dielectric permittivity at radio frequencies and converts it into volumetric water content (VWC), the share of soil volume occupied by water.[1][2]
How FDR Soil Moisture Sensors Work
FDR stands for Frequency Domain Reflectometry. The method belongs to the dielectric family, alongside time domain reflectometry (TDR) and capacitance probes, and it shares one physical fact with all of them: liquid water stores far more electrical energy per unit volume than dry soil or air does. Air has a relative permittivity (εr) of about 1 and dry soil minerals about 3 to 5, while liquid water reaches about 80.[3][4] Water content therefore dominates the dielectric response of any soil volume.
FDR drives the probe with a high-frequency signal and reads the resonant response of the surrounding soil. A wetter soil shifts that response, and the electronics convert the shift into volumetric water content (VWC), the volume of water per unit bulk soil volume.[2] Because the reading depends on the dielectric contrast rather than on weight or on a chemical reaction, no sample has to leave the field.
From dielectric response to volumetric water content
The measurement chain has four stages, and each stage is where calibration decisions live.
- Generate a high-frequency signal. The probe’s oscillator drives the sensing volume, with commercial designs usually operating between 10 MHz and 150 MHz, where the water signal is large and the soil’s salt response is comparatively small.[1][2]
- Measure the response. The probe reads how the signal shifts in frequency and amplitude as the soil’s permittivity changes; this shift is the raw measurement, not yet a water content.
- Convert to volumetric water content. An embedded model maps the shift to volumetric water content (VWC), the share of soil volume filled by water. Readings come straight from the installed probe, with no weighing or sample handling.
- Correct for soil and temperature. The conversion assumes a soil type. Clay content, bulk electrical conductivity (EC), and temperature all move the relationship, which is why a soil-specific calibration is the difference between a trend and a measurement.[1][6]
| Component | Relative permittivity (εr) | Note |
| Air (pore space) | ≈ 1 | Reference low end |
| Soil minerals | ≈ 3–5 | Depends on texture and mineralogy |
| Liquid water | ≈ 80 | Dominates the bulk signal |
| Dry soil bulk | ≈ 2–4 | Mixture of air and minerals |
Why FDR Is Gaining Ground in Irrigated Agriculture
The appeal is not a single headline number. It is the combination of a dielectric measurement with electronics that can run for years on a small battery.
- Direct, continuous readings. Nothing is weighed, dried, or accumulated, so each reading comes straight from the installed probe through the season.
- Low power draw. A short excitation and a low-duty-cycle read fit solar and battery budgets, which is what makes dense networks practical.[11]
- Lower cost per measurement point. Simpler circuitry than TDR means more probes for the same budget, and more probes mean better spatial coverage.[1]
- One probe, several parameters. Combined designs report temperature and bulk EC alongside water content, which supports salinity screening without a second instrument.[12]
- No intake to clog. There is no funnel, no tipping mechanism, and no sampling tube, so the failure modes that dominate mechanical and sampling instruments do not apply.[10]
Where Traditional Methods Still Fit, and Where They Struggle
Every method has a working range, and the honest comparison is about fit rather than a ranking of methods.
Gravimetric sampling remains the reference. Oven drying at 105 °C to constant weight, standardized as ISO 11465, defines water content directly and is used to calibrate every dielectric sensor.[8] It is accurate and inexpensive per sample, and it suits audits, calibration campaigns, and sites where a few reference points are enough. It does not produce continuous data, and it consumes samples and labour.
Tensiometers measure matric potential rather than water content, which is a genuinely different and often more useful variable for irrigation triggering. They suit scheduling decisions in the root zone, and they are inexpensive. Their working range is narrower, they respond slowly as water moves through the ceramic cup, and they need periodic refilling and air purging to keep readings valid.[9]
Mechanical and sampling-based instruments each have a niche. A mechanical tipping-bucket gauge suits standard station networks and budget-constrained sites where rainfall totals matter more than trace resolution; a weighing gauge suits research-grade solid precipitation measurement; an optical gauge suits low-power distributed siting. The same logic applies to soil: a research-grade TDR setup suits reference plots where a single high-accuracy point justifies the cost and power, while FDR suits the many-point, long-dwell coverage that commercial irrigation now expects.[1][5]
The mechanism-level limits of dielectric sensing deserve their own paragraph. Salinity shifts the dielectric–water relationship even at 120 MHz once NaCl exceeds roughly 0.045 mol/L, so a saline block can read wetter or drier than it is.[7] Low-cost resistive and capacitive designs are also sensitive to salt and temperature, which is why factory calibration is a starting point rather than an answer.[11] Clay content changes the conversion slope, so a single generic calibration across a variable field will drift.[1][6]
Where FDR Still Needs Care
Three limits are worth stating before anyone buys a probe.
- Soil-specific calibration. Texture, bulk EC, and temperature range all move the conversion. A calibration against gravimetric samples from the actual field is the most reliable way to convert a repeatable trend into a defensible number.[1][6]
- Salinity and temperature compensation. Bulk EC has to be separated from water content, and the temperature correction has to match the soil, not the air.[7]
- Placement and contact. A probe reads the soil it touches. Cracks, stones, and poor contact create air gaps that bias the reading low, and no calibration can recover a bad installation.[10]
How a Field-Ready Sensor Puts FDR to Work
A probe that measures well on a bench still has to survive a field season. The front end, the power budget, the enclosure, and the radio link decide whether a network returns usable data in year three.
The Seeed Studio SenseCAP S2105 LoRaWAN soil moisture, temperature, and EC sensor assembles that chain in one unit: an FDR-based dielectric probe on a 5 m cable, a replaceable 19 Ah Li-SOCl2 battery, a LoRaWAN v1.0.3 Class A radio with Bluetooth setup, and an IP66 enclosure rated from −40 to +85 °C. One probe returns volumetric water content from 0 to 100% (m³/m³), soil temperature from −40 to +80 °C, and electrical conductivity from 0 to 23 dS/m; the radio reaches about 2 km in urban settings and up to 10 km in line of sight, and the battery lasts up to 10 years depending on reporting interval and gateway distance.[12][13]
On a remote orchard block or a trial plot, a battery-powered LoRaWAN sensor removes the power run and the cellular modem: a gateway handles backhaul, and each sensor joins the network through QR-code binding and Bluetooth setup. A technician inserts the probe and scans the code; from then on the sensor reports on its own schedule, and the gateway covers the radio link. The value is not the probe alone but the fact that a measurement point can be installed in minutes and then left to report.
How to Choose Between Dielectric Soil Moisture Options
The decision usually comes down to four dimensions: what variable the decision needs, how many points the site requires, how often data must arrive, and what calibration and maintenance the team can sustain.
| Comparison dimension | TDR (time domain reflectometry) | FDR (frequency domain reflectometry) |
| Measurement basis | Pulse travel time in the soil; suits reference-grade work. | Resonant response at set frequencies; suits continuous networks. |
| Accuracy and stability | High accuracy; suits labs and calibration plots. | Good accuracy after soil-specific calibration; suits field trends. |
| Power and cost per node | Higher power and cost; suits a few key points. | Lower power and cost; suits many points per field. |
| Data cadence | Fast single readings, usually logged at research intervals. | Frequent readings at set intervals, well suited to telemetry. |
| Comparison dimension | Dielectric (FDR / TDR) | Gravimetric or tensiometric |
| What is measured | Water content from permittivity; suits continuous monitoring. | Mass loss or matric potential; suits audits and scheduling. |
| Continuous data | Native, unattended logging; suits network deployment. | Sample-based or refill-dependent; suits periodic checks. |
| Maintenance burden | No intake, no refill; suits remote sites. | Sampling labour or cup servicing; suits accessible plots. |
| Typical fit | Many points, long dwell, limited site access. | Few reference points with trained staff on site. |
Where These Sensors Earn Their Place
The applications below are the ones where continuous, in-place water content changes a decision.
- Irrigated field crops. Irrigation scheduling needs the depletion curve, not a single afternoon’s reading, and a probe that logs through the season shows whether the last irrigation actually reached the root zone.[9]
- Greenhouse and nursery production. Root volumes are small and change quickly, and sampling on a set schedule catches a missed irrigation event before the crop shows it.[12]
- Orchard and vineyard blocks. Variable soils within one block justify several probes rather than one, and EC from the same probe screens salinity before it shows in the canopy.[12]
- Hydrology and land-restoration plots. Infiltration, recharge, and evapotranspiration studies need water content at depth and through wetting fronts, which suits multi-depth dielectric profiles.[6]
- Research and calibration campaigns. FDR gives dense spatial coverage at modest cost, while TDR and gravimetric samples anchor the calibration.[1][5]
Key Takeaways
- FDR reads water content from the soil’s dielectric response, not from weight or resistance.[1]
- Typical commercial FDR electronics work between 10 MHz and 150 MHz, where the water signal dominates.[1][2]
- Low power and low cost per node let growers deploy more probes per field.[11]
- TDR suits reference-grade measurement; FDR suits networked, continuous coverage.[1][5]
- Calibration and salinity still set the accuracy ceiling in clayey or saline soils.[1][7]
Frequently Asked Questions
What is the difference between FDR and TDR soil moisture sensors?
TDR sends a fast pulse down the probe and times its reflection; FDR drives the probe with a swept or fixed high-frequency signal and reads the resonant response with simpler, lower-cost electronics. Both infer water content from the same dielectric contrast, and TDR keeps the edge in accuracy at a higher cost and power draw.[5][1][2]
How accurate is an FDR soil moisture sensor?
The S2105 is specified at ±3% VWC from 0 to 50% and ±5% from 50 to 100%, with ±0.5 °C soil temperature accuracy between 0 and 50 °C. Confirm the figures against gravimetric samples from your own field.[12]
Does soil salinity affect FDR readings?
Yes, and the effect persists at frequencies as high as 120 MHz for NaCl concentrations above roughly 0.045 mol/L. In saline blocks, calibrate against gravimetric samples or switch to a method that separates bulk EC from water content.[7][1]
Which is better for a solar-powered field network: TDR or FDR?
FDR is usually the better fit for unattended, solar-powered networks, because its simpler electronics draw less power and cost less per node. TDR remains the reference choice where a single high-accuracy point matters more than network density.[11][1]
Can one probe measure soil temperature and salinity as well?
A combined dielectric probe can report temperature and bulk EC alongside water content, and the S2105 does so from one blade-style probe. In saline soils, treat the EC channel as a salinity signal and keep it out of the water-content calculation until the soil is calibrated.[12][11][1] If you need to monitor Pore EC, another model – SenseCAP S2108 is the go-to option.
Standards & Specifications
The reference methods, units, and excitation ranges that the article relies on.
| Item | Specification or practice |
| Gravimetric reference method | Oven drying at 105 °C to constant weight, the reference against which dielectric sensors are checked [8] |
| Water-content unit | Volumetric water content (VWC), expressed as m³/m³ and numerically equal to percent by volume [2] [8] |
| Dielectric contrast used by FDR | εr ≈ 1 in air, ≈ 3–5 in soil minerals, ≈ 80 in liquid water [3][4] |
| Typical FDR excitation | Typically 10 MHz to 150 MHz in commercial dielectric sensor designs [1] [2] |
| Calibration practice | Soil-specific calibration wherever texture, bulk EC, or temperature range departs from the factory reference [1] [6] |
SenseCAP S2105 specifications:
| Parameter | Specification |
| Product type | Battery-powered LoRaWAN soil moisture, temperature, and EC sensor |
| Measurement principle | Frequency domain reflectometry (FDR); dielectric soil probe |
| Parameters measured | Volumetric water content (VWC), soil temperature, electrical conductivity (EC) |
| VWC range | 0–100% (m³/m³) |
| VWC accuracy | ±3% (0–50%); ±5% (50–100%) |
| VWC resolution | 0.1% (0–50%); 0.5% (50–100%) |
| Soil temperature range | −40 to +80 °C |
| Soil temperature accuracy | ±0.5 °C (0–50 °C); ±1 °C (−40–0 °C, 50–80 °C) |
| Soil temperature resolution | 0.1 °C |
| EC range | 0–23 dS/m |
| EC accuracy | ±5% (0–5 dS/m); ±10% (5–23 dS/m) |
| EC resolution | 0.01 dS/m (0–5 dS/m); 0.1 dS/m (5–23 dS/m) |
| Probe and cable | Blade-style soil probe, 5 m cable |
| Enclosure | IP66 |
| Operating temperature | −40 to +85 °C; 0–100 %RH, non-condensing |
| Communications | LoRaWAN v1.0.3 Class A; Bluetooth configuration; 863–928 MHz |
| Radio range | About 2 km in urban settings; up to 10 km in line of sight |
| Power | 19 Ah Li-SOCl2 D-size battery (replaceable, non-rechargeable) |
| Battery life | Up to 10 years, depending on reporting interval, payload, and gateway distance |
| Weight | 405 g |
| Certifications | CE / FCC / RoHS |
Sources & References
- MDPI Sensors (2020). A review of soil moisture measurement methods: principles, calibration, and wireless deployment. https://www.mdpi.com/1424-8220/20/13/3733
- MDPI Sensors (2010). Frequency domain analysis of soil dielectric properties. https://www.mdpi.com/1424-8220/10/4/2622
- University of Wyoming Extension. B1331: Soil moisture monitoring and irrigation scheduling. https://www.wyoextension.org/publications/PDFs/B1331.pdf
- ACSESS / Soil Science Society of America (2022). Soil dielectric properties and water content measurement. https://acsess.onlinelibrary.wiley.com/doi/10.1002/saj2.20452
- University of Florida IFAS Extension. AE266: Time domain reflectometry for soil water content. https://edis.ifas.ufl.edu/publication/AE266
- CORE / EGU. Short-probe frequency domain reflectometry: field calibration and performance. https://core.ac.uk/download/pdf/159295486.pdf
- AGU Water Resources Research (2002). Salinity effects on soil dielectric measurements at 120 MHz. https://agupubs.onlinelibrary.wiley.com/doi/10.1029/2001WR000905
- ISO 11465:1993. Soil quality — Determination of dry matter and water content on a mass basis — Gravimetric method. https://www.iso.org/standard/20870.html
- University of Florida IFAS Extension. AE266: Tensiometers for soil moisture measurement. https://edis.ifas.ufl.edu/publication/AE266
- North Carolina State University Extension. Soil moisture sensors for irrigation scheduling. https://content.ces.ncsu.edu/soil-moisture-sensors-for-irrigation-scheduling
- MDPI Sensors (2020). Low-cost capacitive and resistive soil moisture sensors: performance and calibration. https://www.mdpi.com/1424-8220/20/2/671
- Seeed Studio. SenseCAP S2105 LoRaWAN Soil Moisture, Temperature, and EC Sensor product page. https://www.seeedstudio.com/SenseCAP-S2105-LoRaWAN-Soil-Temperature-Moisture-and-EC-Sensor-p-5358.html
- MDPI Sensors (2025). Advances in dielectric soil moisture sensing for precision irrigation. https://www.mdpi.com/1424-8220/25/3/1042
Read More from the Sensor Know-How Series
This article is part of the Weather Sensor Know-How series, which explains how environmental sensors work, what their specifications mean in the field, and where each technology fits. The installments below cover the measurement principles behind the rest of a weather station.
- Giving Soil a “CT Scan”: Soil Moisture Sensors Explained
- Why Is Your Rain Gauge Underestimating Rainfall? A Radar Rain Gauge Comparison with Optical and Tipping Bucket Gauges
- How Strong Is the Sunshine? Two Core Technologies Behind Solar Radiation Monitoring
- From Cup-and-Vane to Ultrasonic: How We Measure Wind with Precision
Browse the full series: Sensor Know-How series archive
Talk to Our Team
If you are specifying soil moisture monitoring for an irrigation network, a research plot, or a restoration site, tell us the soil type, the depth, and the reporting interval you need. Write to [email protected], and let us know which measurement topic you would like to see explained next in the Sensor Know-How series.
