DSO nano - Pocket size digital storage oscilloscope
SKU 109990029
89.00
DISCONTINUED
This product is discontinued, we have a new version DSO Nano v3 instead of DSO nano - Pocket size digital storage oscilloscope.
DSO nano is a pocket size digital storage oscilloscope fulfills basic electronic engineering requirements. It is base on ARM Cortex™-M3 compatible 32 bit platform, equipped with 320*240 color display, SD card capability, USB connection, and chargeable batteries. Weighs only 60g.
Features:
Display 2.8″ Color TFT LCD
Display Resolution 320×240
Display Color 65K
Analog bandwidth 0 - 1MHz
Max sample rate 1Msps 12Bits
Sample memory depth 4096 Point
Horizontal sensitivity 1uS/Div10S/Div (1-2-5 Step)
Horizontal position  adjustable with indicator
Vertical sensitivity  10mV/Div10V/Div (with ×1 probe)
  0.5V/Div100V/Div (with ×10 probe)
Vertical position  adjustable with indicator
Input impedance >500KΩ
Max input voltage  80Vpp (by ×1 probe)
Coupling DC
Trig modes Auto, Norma, Single, None and Scan
Functionalities: Automatic measurement: frequency, cycle, duty, Vpp, Vram, Vavg and DC voltage
  Precise vertical measurement with markers
  Precise horizontal measurement with markers
  Rising/falling edge trigger
  Trig level adjustable with indicator
  Trig sensitivity adjustable with indicator
  Hold/run feature
Test signal Built-in 10Hz1MHz (1-2-5 Step)
Waveform storage SD card
PC connection via USB as SD card reader
Upgrade  by bootloader via USB
Power supply 3.7V Chargeable Lithium battery / USB
Dimension (w/o probe) 105mm X 53mm X 8mm
Document:
Package list:
  • DSO nano body x 1
  • 3.7v lithium battery with connector x 1
  • Back plate x 1
  • Mini Probe x 1
  • Manual X1
  • Protection bag  X1
Resources:
You can also have a nice stand for your DSO nano here.
Technical Details
Dimensions0mm x 0mm x 0mm
WeightG.W 180g
BatteryExclude
ECCNNot Available
Reviews
Questions and Answers
SUBMIT
0
How do I update my firmware for the Nano Dos 201
on Mar 15,2017
Reply upvote ()
    View History
    SKU 109990029
    $89.00
    DISCONTINUED
    $89.00/ 1pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
