Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
⚠️Buying Guide
This is a DIY kit and requires assembly before use. Items pre-selected are essential for smooth robotic arm operation. Feel free to uncheck them if you already have these parts. If you'd like to explore teleoperation, please purchase the "Star Arm 102 (Leader Arm)" and "12V 2A AC/DC Adapter (5-in-1)" together. A mounting G-clamp is required to securely fix the robotic arm to a workbench. All other accessories are optional and can be purchased as needed.
Fully Open-Source: 100% open-source robotic arm, certified with CERN-OHL-W 2.0, in terms of both hardware and software. It includes the BOM list, hardware drawings, software, and algorithms, everything you need.
Detailed Assembly Tutorials: Provides extremely detailed illustrated and video assembly tutorials, wiring instructions, calibration procedures, and environment deployment tutorials, lowering the entry barrier for robot development.
High-performance motors: The reBot Arm B601-RS uses 4pcs RS-00 motors and 3pcs RS-06 high-torque, low-noise high-performance motors, providing the robotic arm with stable and precise power output..
Framework Compatibility: Supports mainstream robotics development frameworks such as ROS1/2, NVIDIA Isaac Sim, Hugging Face LeRobot, Pinocchio, etc.
Constant Content Updates: As the project progresses, we will gradually update the latest trending algorithms and launch a series of completely free tutorials.
Degrees of Freedom6+1
Reach754.7mm
587.5mm(without gripper)
Payload2.5kg (Rated load)
5kg(Maximum load)
Joint Range of MotionJ1:±150°
J2:220° - 0°
J3:220° - 0°
J4:±90°
J5:±90°
J6:±180°
夹爪:345° - 0°
Repeatability0.1 mm
Weight6.7kg
ServosROBSTRIDE 06 x3
ROBSTRIDE 00 x4
Operating Temperature-20°~50°
PowerDC 48V 15A
ROS1✅
Moveit1✅
ROS2✅
Moveit2✅
Python✅
Lerobot✅
Isaac Sim✅
Pinocchio✅
Open Source✅
Application
Learn & Build Robotics Easily
Lower the barrier to robotics with step-by-step tutorials, open-source tools, and real-world examples. Designed for students, makers, and first-time developers, the reBot Arm B601-RS helps you go from assembly to intelligent robot control quickly and confidently.
Research & Laboratory Automation
High-precision robotics for liquid handling, sample transfer, and laboratory workflows. Built for repeatability, delicacy, and rapid experimentation.
Teleoperation & Physical AI
Power real-time control, data collection, and sim-to-real learning with leading robotics frameworks including LeRobot and Isaac Sim. A dexterous “hand” for embodied AI.
Industrial Automation & Logistics
±0.1 mm precision, up to 5 kg payload. The reBot Arm B601-RS enables precision assembly, inspection, sorting, and material handling in manufacturing and warehouse environments. Compact and easy to integrate into existing production lines and workcells.
reBot Arm B601-RS Body Structure Kit
Item Name
Quantity
Body metal parts
17
Main body print
19
Bearing
4
KM3x7mm
50
KA3x12mm
48
HM3x8mm
33
HM4x8mm
6
HM4x16mm
18
HM4x70mm
4
Hex key wrench set
1
Mouse pad
1
reBot Arm B601-RS Body Motor Kit
Item Name
Quantity
RobStride 06 QDD 36 N.m integrated actuator module(pre-assembled)
3
RobStride 00 QDD 14N.m integrated actuator module(pre-assembled)
3
RobStride USB-CAN Driver Board
1
CANABLE
1
XT30 2+2 Power Separation Board
1
Wire kits
1
Mouse pad
1
reBot Arm B601-RS Gripper Kit
Item Name
Quantity
1
Claw Metal Parts Set
1
Paw Print Kit
1
Guide rail kit
1
Gear and rack set
1
Hex key wrench set
1
Mouse pad
1
Wire kits
1
KM3x7mm
15
KM3x16mm
11
KA3x12mm
11
HM3x6mm
11
HM3x12mm
10
HM3x26mm
9
reBot Arm B601-RS Unassembled Kit
SKU E26070302
Built to be truly open. Featuring a 2.5 kg rated payload and ±0.1 mm repeatability, the reBot Arm B601-RS combines fully open hardware and software with comprehensive tutorials, making sim-to-real learning, teleoperation, and real-world robotics development more accessible than ever.
Robot Arm
Assembly Type
AI Computing Platform
USD$1476.00
reBot Arm B601-RS Body Structure Kitx1$269.00
reBot Arm B601-RS Body Motor Kitx1$929.00
reBot Arm B601-RS Gripper Kitx1$199.00
Power Adapter Kit for reBot Arm B601-RSx1$79.00
You may also add
