ARDX - Basic Experimentation Kit for Arduino
SKU 110060447
29.90
50+ Available
$29.90/ 1pcs+
NOTE: This kit DOES NOT include the Arduino board, please visit ARDX - The starter kit for Arduino if you need an extra Arduino in the kit.
People gets bored easily these days, while we believe engineering can always simulate the mind. That is actually how most of literate parents enlighten their kids, inspiring them with engineering. They firstly start with SIMPLE, FUN and BASIC experiments – using a range of electronic components to build easy circuits, let the kids feel the fun in it, and meanwhile learn how it works.
The ARDX - Basic Experimentation Kit for Arduino is such a kit that helps beginners perceive the knowledge of electronics. Not only the kit includes a wide range of electronic components, but also it provides a detailed Experimenter’s Guide that illustrates up to 13 different circuit diagrams constructed with easy-to-use breadboard. After bread-boarding your own circuit as instructed, you will be familiar with basic elements of LEDs, resistors, photo sensors and temperature sensors etc. Then you can go even further with some more advanced components like piezo elements, relay, DC motor and servo.
Some of you might prefer reading the guide online, there is also an electronic version of the Experimenter’s Guide, which can be downloaded here.
Also if you encounter any problems, want to ask some questions, or would you like to know more about any parts, extra help is only an e-mail away at help@oomlout.com.
  • Designed for beginners
  • Simple, easy bread-boarding circuit learning
  • Help you grasp the use of basic elements, and also get to know some advanced electronic components
  • 13 circuits at different level for you to learn progressively
  • A color printed Experimenter's Guide included, providing step-by-step instructions
  • 75x Premium jumper wires
  • 1x Type B USB cable
  • 1x 9V battery clip
  • 1x 5mm diffused RGB LED
  • 1x Piezo Sensor - Minisensor 100
  • 10x 5mm red LEDs
  • 10x 5mm green LEDs
  • 1x 10mm blue LED
  • 1x Toy DC motor
  • 1x 9g High Sensitive Mini sensor
  • 1x 74HC595
  • 1x Buzzer
  • 1x 1M resistor
  • 2x Pushbuttons
  • 1x Potentiometer (10K)
  • 1x Light sensor (5528)
  • 1x TMP36
  • 1x Relay (5v,3A/120VAC)
  • 2x P2N2222A
  • 25x 560 Ohm resistors
  • 3x 2.2k Ohm resistors
  • 3x 10k Ohm resistors
  • 1x 220uf capacitor
  • 2x 1N4001
  • 1x Breadboard
  • 1x Male pin header
  • 4x Plastic rivet
  • 1x Acrylic holder
  • 4x Rubber bumpers
  • 13x Color breadboard layout sheets
  • 1x Full color printed Experimenter’s Guide
Documents
  • For technical discussion, please come to our Forum.
  • For projects that you would like to share with the community, please visit Recipe.
Technical Details
Dimensions190mm x 120mm x 45mm
WeightG.W 414g
BatteryExclude
Premium jumper wires75
Type B USB cable1
9V battery clip1
5mm diffused RGB LED1
Piezo Sensor - Minisensor 1001
5mm red LEDs10
5mm green LEDs10
10mm blue LED1
Toy DC motor1
9g High Sensitive Mini sensor1
74HC5951
Buzzer1
1M resistor1
Pushbuttons2
Potentiometer (10K)1
Light sensor (5528)1
TMP361
Relay (5v,3A/120VAC)1
P2N2222A2
560 Ohm resistors25
2.2k Ohm resistors3
10k Ohm resistors3
220uf capacitor1
1N40012
Breadboard1
Male pin header1
Plastic rivet4
Acrylic holder1
Rubber bumpers4
Color breadboard layout sheets13
Full color printed Experimenter’s Guide1
ECCNNot Available
HSCODE9023009000
Reviews
Questions and Answers
SUBMIT
    View History
    SKU 110060447
    $29.90
    50+ Available
    $29.90/ 1pcs+
    • Related
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
