Europe Standard USB Wall Power Supply 5VDC 2.1A - CE Intertek GS
Rating:
100% of 100
This high quality AC to DC power supply is "wall wart" type, featuring short circuit protection, over current protection and efficient AC to DC conversion over 80%
$6.95
Out of stock
  • 10+: $6.26
  • 20+: $5.91
This high quality AC to DC power supply is "wall wart" type, featuring short circuit protection, over current protection and efficient AC to DC conversion over 80%.
These have a standard USB ‘type A’ connector for the output so you can power your Raspberry Pi, Cubieboard, etc. through a USB cable. Any device that uses a USB cable for charging or power can be powered with this supply.
And, This version in accordance with European standard interface.
Feature:
  • Wall mount type
  • Short circuit protection
  • Over current protection
  • Conversion efficiency more than 80%
  • Compatible with Raspberry Pi A+,B,B+/2.
Specification:
  • Rated Input: 100-240V AC~50/60Hz 0.3A
  • Rated Output: 5V/2.1A
  • Connector: USB Female
  • Certifications: CE
  • Size: 5.5cm x 3cm
Dimensions 0mm x0mm x0mm
Weight G.W 49g
Battery Exclude
HSCODE 8504409990
USHSCODE 8504409580
UPC 841454116271
Product Faqs
Sort by
