Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • High-performance Motor and Gear System: Equipped with a coreless motor and metal gears, delivering high torque (2.5kg.cm @ 6V, 3.5kg.cm @ 7.4V) and low no-load current (140mA @ 6V, 180mA @ 7.4V).
  • High-precision Control: Features a 12-bit magnetic encoder for 360° absolute position control with 0.088° resolution, supporting multiple operating modes.
  • Feedback: Provides comprehensive feedback on load, position, speed, input voltage, current, and temperature.
  • Electronic Protection: Includes overload, overvoltage, and overheat protection to ensure reliable operation.
  • Flexible Communication and Interface: Supports half-duplex asynchronous serial communication (38400bps to 1Mbps) with customizable baud rates and IDs, using a PH1.25-3P interface.
Product
Feetech HL-3615-C002 6V 2.5Kg Servo
Dimensions
34×20×23 mm
Weight
35.8±2 g
Voltage Range
5V-8.4V
Operating Voltage
6V (Standard)
7.4V (High Voltage)
No-Load Speed
0.034 sec/60° (290RPM)
0.027 sec/60° (365RPM)
Stall Torque
2.5kg.cm
3.5kg.cm
Rated Load
0.8kg.cm
1.2kg.cm
Operating Temperature
-20℃~60℃
Hardware Overview
Documents
Certification
HSCODE8501109990
USHSCODE8501106080
UPC
EUHSCODE8501109390
COOCHINA
HL-3615-C002
x1
M2*4
x8
15cm -1.25mm to 5264 terminal wire
x1
20cm -1.25mm terminal wire
x1
SKU 100039104
It's designed for high-speed and moderate torque applications. It offers a speed of 363 RPM and a gear ratio of 1/96, making it ideal for small robotics, robot arms, small products, and low-torque drive applications. This servo provides a balance of speed and torque for a wide range of tasks.
USD$40.00
You may also add
