Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
【Note】
  • From China warehouse to the United States, choose "US Direct Group Shipping" to enjoy duty-free!
  • High Precison Provides 360-degree positioning with precise angle control and multi-turn continuous rotation capability
  • Metal Gearbox Includes 1:345 gear reduction ratio metal gearbox
  • Easy Calibration Offers one-touch midpoint calibration
  • Rich output Provides real-time feedback of position, speed, voltage, current, temperature, and load
  • Overload protection Provides overload and overcurrent protection
Product
Feetech ST3215 C001
Voltage
5V ~ 8.4V
Operating Temperature
-20℃~60℃
Mechanical Dimension
45.2mm x 24.7mm x 35mm
Communication Interface
Serial
Hardware Overview
Application
Certification
HSCODE8501109990
USHSCODE8501106080
UPC
EUHSCODE8501109390
COOCHINA
ST3215-C001 Servo
x1
Servo Horn
x2
Screw
x18
JST Wire
x1
Feetech ST3215 C001 Servo 7.4V 1:345 Gear Ratio
SKU 108090023
STS3215 C001 is 7.4V 19kg serial bus smart servo, with plastic case, core motor, 1:345 metal gearbox and 12 bit high precision magnetic coding sensor. The stall torque is 19.5 kg. cm and the rated torque is 5kg. cm. Designed for versatility, it is suited for use in industrial automation, robotics, and low-torque drive applications, such as LeRobot SO-Arm 101.
USD$20.00
You may also add
