Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Ultra-Compact Size Suitable for robotics applications that requires compact footprint, such as microrobot joints and dexterous hands
  • Metal Gearbox Includes 1:416 gear reduction ratio metal gearbox
  • Rich output Provides real-time feedback of position, speed, voltage, current, temperature, and load
  • 10-bit encoder Provides 1024-step resolution for precise closed-loop control
  • TTL Serial Communicates through serial connection that can be daisy-chained with a single 3-pin wire
Product
Feetech SCS0009
Voltage
4V ~ 7.4V
Operating Temperature
-20℃~60℃
Mechanical Dimension
23.2mm x 12.1mm x 25.25mm
Communication Interface
Serial
Hardware Overview
Certification
HSCODE8501109990
USHSCODE8501106080
UPC
EUHSCODE8501109390
COOCHINA
SCS0009 Servo
x1
Servo Horn
x3
Screw
x3
JST Wire
x1
JST Board
x1
Feetech SCS0009 Ultra-Compact Servo 6V 2.3kg for Amazing Hand and HopeJR
SKU 100067882
SCS0009 is 6V 2.3kg serial bus ultra-compact smart servo, with plastic case, core motor, 1:416 metal gearbox and 10 bit high precision magnetic coding sensor. The stall torque is 2.3 kg. cm and the rated torque is 0.75kg. cm. Because of its compact size, SCS0009 can be used as actuators in dexterous hand or microrobotics, such as Amazing Hand.
USD$9.00
You may also add
