Grove - XBee Carrier
SKU 113020004
15.95
12 Available
$15.95/ 1pcs+
$14.36/ 10pcs+
XBee Carrier is a Wireless Sensor Network (WSN) base board designed for Bee series and groves. It is primarily suitable for standalone Bee Nodes like RFBee, Wifi Bee which have ATMega328 onboard. It is compatible with RFBee, Wifi Bee , XBee and Bluetooth Bee. Besides a Bee receptacle, there are also two Grove connectors. The board cab be powered by a lithium battery or through USB cable. You can use a Wireless charger, Solar Panel or the USB cable to charge the battery. The FT232RL chip onboard helps in downloading the program to Bee Module directly.
Bees which do not have ATMega328 like Bluetooth Bee can only be configured by using on-board FT232RL(USB to UART). Theses Bees are not suitable for standalone applications.
The on-board FT232RL can be used like any other 3.3V USB to UART interface when not connected to any Bee Modules. This is useful for programming a 3.3V MCU through Serial Port.
  • Bees compatible receptacle
  • Two grove connector - one for I2C and other for D6,D5
  • Two grove place holders
  • On-Board Charge Controller CN3063
  • On-Board 3.3V LDO Lownoise Micropower Regulator - RT9167A_33PB
  • On-board FT232RL UBS-UART IC
  • LEDs for PWR, charge indication and UART transmission.
  • Power switch
  • Reset button
  • 2.0mm pitch JST connector for Battery and Charger.
Application Ideas
  • Wireless Sensor Network with Standalone Bee Node like Wifi Bee.
  • As a configuration aid for Bees using FT232RL.
  • Charger for Lithium Ion Cells using on-board charge controller.
  • As a FT232RL based 3.3v USB-UART.
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Technical Details
Dimensions130mm x 90mm x 10.50mm
WeightG.W 20g
BatteryExclude
Grove - XBee Carrier1
ECCNEAR99
HSCODE8517709000
Certification
RoHSCompliant
Reviews
Questions and Answers
SUBMIT
0
Many XBee modules include a PCB antenna at the tapered end of the module. To maximize range, if you ever redesign this hardware, you should ensure that there aren't any components below that area, including traces and ground planes.
on Sep 21,2017
Reply upvote ()
Hi,Tom~We appreciate your comment.Could you please tell us more.Your suggestion is out of your experience or some Microwave Technology and Antenna theory.We really thank you,but we need to know more.Thanks agian.
on Sep 21,2017 10:45 AM
Reply upvote ()
Reply
0
Maybe you can refer to the wiki of XBee carrier first (http://www.seeedstudio.com/wik... and get more information about it, almost all of it have been posted there.
on Oct 19,2016
Reply upvote ()
I dont understand your answer, you say "view our WIKI to know more" where can i view it? and what is it included. thank you
on Oct 20,2016 10:41 AM
Reply upvote ()
Reply
0
Hi, sorry my question but, this device can send data to other XBEE without Arduino? (or other). Grove - Xbee Carrier can be programmed as Arduino? or I need a Arduino to send data from sensors to other xbee. if the response is yes, here sale the connec
on Oct 19,2016
Reply upvote ()
Hi, suggest you attach what you need in the forum would be better, lot of people was done and you can ask them for some experience.
Reply upvote ()
Maybe you can refer to the wiki of XBee carrier first (http://www.seeedstudio.com/wik... and get more information about it, almost all of it have been posted there. Good luck.
on Oct 20,2016 10:48 AM
Reply upvote ()
Reply
0
Hey! This looks like a great solution. I apologize if this has been answered already, but can this be powered by anything besides the USB connector? Specifically, I was wondering if there was a way that this can be used solely via the Grove connectors.
on Oct 19,2016
Reply upvote ()
1)The connector of charger can be powered by solar panel, and if you have something other power, you can plug it onto the connector of BAT, normally, a 3.7v battery. 2) Also, the XBee carrier can only be powered by Grove connectors, but the input volta
Reply upvote ()
Reply upvote ()
Reply
0
Carrier lights are on all the time - When i switch on power - pwr, rx & tx are all lit. After inserting an XBee Pro 900 Digimesh (DMSIT) module the lights stay on but the XBee which transmits analog data every 5 seconds when power by a different board
on Oct 19,2016
Reply upvote ()
It is in stock for now. The next batch would be ready at the beginning of Jan. 2012.
Reply upvote ()
It doesn't matter, this phenomenon happens sometimes while Carrier is not connecting to PC via USB port. It's a usual phenomenon when the VCC of FTDI chip is not powered. This phenomenon would disappear after providing a power to Carrier via USB port.
Reply upvote ()
Reply
0
Just to confirm. The input voltage for the board is 3.0 - 3.6v/Thanks
on Oct 19,2016
Reply upvote ()
hi,actully, this shield can be controlled just with a serial port. that is, you can control it with every controller that has a serail port. as the example, it is the same with seeedduino and netduino, you just need to use the serial port on netduino,
Reply upvote ()
Hi,Randy.Yes,you can work with 3.0~3.6v ,As a FT232RL based 3.3v USB-UART.with a happy day~
on Oct 20,2016 10:47 AM
Reply upvote ()
Reply
0
Hi!Is it possible to simultaneously connect an Grove - Infrared Emitter and a Grove - Temperature&Humidity Sensor Pro? The idea is to have a carrier board (with XBee module) that is capable of forwarding commands to an IR controllable device and
on Oct 19,2016
Reply upvote ()
Hi,Toom. of course you can,just try!we hope that you can share your works when you finish it.with a happy day~
Reply upvote ()
Reply
0
Hi,Can / how the standalone bee know the battery charge level ?ThanksBernard
on Oct 19,2016
Reply upvote ()
... may I know how - from arduino ? :-)
on Oct 20,2016 10:46 AM
Reply upvote ()
Reply
0
I connect the Temp & Humid Sensor to this Xbee Carrier along with Wifi Bee, but when I tried to use an example sketch to get Temp & Humid value it returns timeout or no value received, the tutorial says to use pin 2 (note : it is for DHT11 that has 4 p
on Oct 19,2016
Reply upvote ()
Jacket Chueng : can you give me some more spesific tutorial in this thread please? I really need it, thankshttp://www.seeedstudio.com/for...
on Oct 20,2016 10:45 AM
Reply upvote ()
Reply
0
I want to know if this unit could be used as an Xbee Explorer Board and used to globally broadcast to other Xbee receivers. I am converting all of my Christmas Light Display Boards to Wireless and I need an explorer board to use as a transmitter from t
on Oct 19,2016
Reply upvote ()
Hi,yes u can.And you can use a RF Bee as global transmitter, and the others can use as receivers.
on Oct 20,2016 10:44 AM
Reply upvote ()
Reply
    View History
    SKU 113020004
    $15.95
    12 Available
    $15.95/ 1pcs+
    $14.36/ 10pcs+
    • Description
    • Technical Details
    • Learn
    • Reviews
    • Questions and Answers
    SUBMIT
