the AI Hardware Partner
Toggle Nav
Loading...
Grove - GPS (Air530),GPS location, Long-distance communication
Grove-GPS (Air530) is a high-performance, highly integrated multi-mode satellite positioning and navigation module, supporting plenty of location systems, such as GPS/Beidou/Galileo and etc.
$11.00
In stock
  • 10+: $8.00
Feature
  • Highly Integrated Multi-mode Satellite Positioning: Multi-mode satellite positioning & navigation and support more than 6 satellites at the same time
  • High precision Positioning: Positioning error within 10 meters,and the position still quickly and accurately under the condition of bad signal
  • The Integrated Design of RF Baseband: Adopt the integrated design of RF baseband, which integrates DC/DC, LDO, LNA, RF front-end, baseband processing, 32-bit RISC based chip, RAM, FLASH storage, RTC, and power management functions
  • Low Power Consumption: Low power consumption at only 31uA
  • High Compatibility: Compatible hard/soft interface for other modules
Confused about your GPS not working well in urban or outsides under only one or a few satellite module? Then you should not miss our new Grove-GPS (Air530). It’s a high-performance, highly integrated multi-mode satellite positioning and navigation module to use with Arduino. It supports GPS / Beidou / Glonass / Galileo / QZSS / SBAS, which makes it suitable for GNSS positioning applications such as car navigation, smart wear, and drone. Meanwhile, this module is capable of receiving more than 6 satellites at the same time and is able to work excellently even if there's a very bad signal.
Grove – GPS Module vs Grove – GPS (Air530)
Specs Grove – GPS Module Grove – GPS (Air530)
Size 40mm x 20mm x 13mm 40mm x 20mm x 13mm
Update Rate 1Hz, max 10Hz
Baud Rate 9,600 – 115,200 9600 –921600
Navigation Sensitivity -160dBm –166dBm
Power Requirements 3.3/5V 3.3/5V
Number of Channels 22 tracking, 66 channels
Time to first start Cold start: 13s
Warm start: 1-2s
Hot start: <1s
Cold start: 30 seconds
Warm Start: 4 seconds
Antennas Antenna included Antenna included
Accuracy 2.5m GPS Horizontal Position Accuracy 2.5m Horizontal positioning accuracy
Specification
parameters values
Supply voltage 3.3V/5V
Working current up to 60mA
Interface UART
Time of warm start 4s
Time of cold boot 30s
Working Temperature -35C-85°C
Storage Temperature -55°C-100°C
Humidity 5%-95%
Time of Positioning
Pure hardware cold start 27.5s
Pure hardware hot start <1S
Pure hardware recapture <1S
Software-assisted A-GNSS <5S
Sensitivity
Cold start -148dBm
Hot Start -162dBm
Recapture -164dBm
Track -166dBm
Accuracy
Horizontal positioning accuracy 2.5m
High positioning accuracy 3.5m
Speed accuracy 0.1m/s
Time transfer accuracy 30ns
Consumption
Capture current [email protected] 42.6mA
Tracking current [email protected] 36.7mA
Low power [email protected] 0.85mA
Ultra-low-power [email protected] 31uA
Note
The test above is taken under bi-modules of GPS&Beidou.
Pinout
Applications
  • GPS tracker
  • GPS navigation
  • Distance measurement
  • Car navigation
  • Drone
Part list
Items Values
GPS (Air 530) board 1
Grove cable 1
Cautions
  • The input power supply voltage of Grove power supply interface, should not exceed 5.6V, otherwise it may damage the device.
  • The voltage of the selected button battery should not exceed 3V, or it will probably damage the device.
HSCODE 8526919090
USHSCODE 9026104000
UPC
EUHSCODE 9013101000
COO CHINA
EU DoC 1
RoHS 1
UK DoC 1
  1. Product Quality
    100%
    Documentation
    80%
    from order view
    Jut received, it seems excellent, but I've yet to use.
    By
  2. Product Quality
    100%
    Documentation
    100%
    from order view
    Can't beat the price with the ceramic antenna.
    By
  3. Product Quality
    100%
    Documentation
    80%
    from order view
    I am excited to try it out. With a codebase on github and some other project instruction documentation I am feel really good about jumping in. There is no documentation included in the package, but I actually prefer that. I have a printer if i want printed materials.
    By
  4. Product Quality
    100%
    Documentation
    80%
    from order view
    Easy to use
    By
  5. Product Quality
    100%
    Documentation
    80%
    from order view
    Good product, easy to use
    By
Items 6 to 10 of 20 total
Show per page
