Grove - Rotary Angle Sensor(P)
Rating:
50% of 100
Rating:
50% of 100
$2.90
In stock
10+ Available
Qty Discount available
  • $2.61 /10pcs+
  • $2.47 /20pcs+
  • $2.32 /50pcs+
What does “P” mean? “P” is for “panel mount” in this product. This Grove – Rotary Angle Sensor is a sister version of original Grove – Rotary Angle Sensor. They are identical except the Grove connecter is moved to the back so that you can easily use it as a neat and wire-free human interface device.
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Dimensions 20mm x20mm x20mm
Weight G.W 10g
Battery Exclude
Grove - Rotary Angle Sensor(P) 1
ECCN EAR99
HSCODE 9031900090
ROHS 1
Using Grove-Rotary Angle Sensor(P) to Control Grove LED
Using Arduino/Genuino 101 to control the brightness of an LED through Grove-Rotary Angle Sensor(P) .
Christmas Sous Vide Feast
As a foodie, I have always longed for some sous vide dishes. However I haven’t got a chance to try it yet. [Sous vide (/suːˈviːd/) comes from French, means "under vacuum", a method of cooking in which food is sealed in airtight then placed in a
This is wiki for Grove - Rotary Angle Sensor(P).
Product Faqs
Sort by
