Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
You can also check out our IndoorPositioning
Step 1: Select a Tracker
Worn by the tracked object, it acquires and reports its position via GPS, Bluetooth, or Wi-Fi.
Selection Criteria
Quantity
Total number of tracked objects = Number of trackers required
Model
Select based on the reported data and development needs. Refer to the Tracker Selection Comparison Table.
Step 2: Select a LoRaWAN® Gateway
Receives data from trackers and transmits it to the server via Ethernet/4G.
Selection Criteria
Quantity
A single Device covers a radius of 2-5 km. Estimate the quantity based on site area and obstacles.
Deployment Environment
Choose a device with the appropriate protection rating based on the gateway's deployment location (indoor/outdoor).
Power Supply
For outdoor locations without a power source, choose a gateway with a battery / solar power.
Network Conditions
Choose an Ethernet Gateway if a wired network is available. Choose a 4G Gateway for wireless or flexible deployments.
Frequency Band
[Required] Select the corresponding frequency band based on the project's country/region.
Eg. EU - 863 , US - 915, Japan - 923
Step 3: Select Beacons (Indoor Only)
Indoor GPS signals are weak and inaccurate. Therefore, beacons are needed indoors to transmit Bluetooth signals, providing a positioning reference for trackers. The required quantity varies significantly based on desired accuracy and area:
Indoor Positioning Accuracy
Effect
Suggested Deployment Density
Zone-level (~15m)
Determine if an object is in a specific room or area
Every 10-20 meters
Meter-level (2-5m)
Obtain precise indoor coordinates
Every 3-7 meters
Step 4: Select a Computing and Storage Platform
The "brain" of the solution, responsible for data processing, storage, and visualization. If you use the SENSECAP , no additional local server is required.
Deployment Mode
Advantages
Requirements
SenseCraft Public Cloud (Recommended)
Simple, fast, maintenance-free, with API and open-source Software
Gateway requires internet access
Private On-Premises Deployment
Data is completely private and highly secure
Requires self-deployment of servers and certain technical skills
Application
SenseCraft provides a complete set of general-purpose tools compatible with the hardware, from device configuration and data reading to AI model deployment, making it easy to build your own solutions
We have open-sourced a demo application for Indoor Positioing. It's ready to use out-of-the-box, and you can use it as a reference to build your own solution.
Indoor & Outdoor Integrated Positioning
SKU E2025081201
By integrating GPS, Wi-Fi, and Bluetooth multi-modal positioning technologies, we offer an out-of-the-box, integrated hardware and software solution for indoor and outdoor positioning. Whether for personnel tracking or asset monitoring, this solution provides real-time, reliable location data, eliminating blind spots. Paired with easy-to-use hardware and fully open-source software, you can effortlessly develop customized applications for logistics, security, and asset management, achieving comprehensive "visibility of everything."
USD$154.90
BC02 Outdoor Bluetooth Location Beacon for SenseCAP Trackerx1$16.00
SenseCAP T1000-A LoRaWAN Tracker for Indoor and Outdoor Positioningx1$39.90
SenseCAP M2 Multi-Platform LoRaWAN Indoor Gateway(SX1302) - US915x1$99.00
You may also add
