Product Details
Wiki & Learn
Reviews
Download PDF
Feature
The main difference between SMA and RP-SMA
Threading (Gender)
Center Contact (Polarity)
SMA Male
Internal Threads
Pin (Center Plug)
SMA Female
External Threads
Hole (Center Jack)
RP-SMA Male
Internal Threads
Hole (Center Jack)
RP-SMA Female
External Threads
Pin (Center Plug)
Best Practice
Item / Parameter
Specification / Details
Cable Length
300.0 ± 8.0 mm
Inner Conductor
Silver plated copper, Φ0.52 ± 0.01 mm
Dielectric
PTFE, Φ1.53 ± 0.05 mm
Outer Conductor
Silver-Plated Copper Wire Braiding, Φ1.95 ± 0.05 mm
Jacket
FEP (Grey), Φ2.50 ± 0.05 mm
Capacitance
106 pF/m
Connectors
RP-SMA male to N-Type SMA Female
Impedance
50 ± 2 Ω
Max. Operating Frequency
0 ~ 6 GHz
Voltage Withstand (AC)
0.5 kVrms (1 min)
Shielding Effect
> 60 dB (0-1G)
Min. Bending Radius Static
15 mm
Operating Temperature (Cable)
-65°C to +150°C
Attenuation @ 0.5 GHz
0.2676 ± 0.10 dB/m
Attenuation @ 0.6 GHz
0.3163 ± 0.10 dB/m
Attenuation @ 0.8 GHz
0.3310 ± 0.10 dB/m
Attenuation @ 1 GHz
0.4043 ± 0.10 dB/m
Attenuation @ 2 GHz
0.6956 ± 0.15 dB/m
Attenuation @ 3 GHz
0.6835 ± 0.15 dB/m
Attenuation @ 4 GHz
0.9624 ± 0.18 dB/m
Attenuation @ 5 GHz
0.9989 ± 0.20 dB/m
Attenuation @ 6 GHz
1.0138 ± 0.20 dB/m
Connector Frequency Range
DC-6 GHz
Connector Nominal Impedance
50 Ω
Connector Working Voltage
335V Max.
Connector Proof Voltage
750V
Connector VSWR
1.4 Max.
Connector Torsional
15 IN-LBS Min.
Connector Pluggable
500 cycles
Connector Operating Temp.
-55°C to +125°C
Salt Spray
48 Hours
Compliance
RoHS & REACH Compliant
Hardware Overview
Certification
HSCODE8544200000
USHSCODE8544421000
UPC
EUHSCODE8544119000
COOCHINA
RP-SMA Male to N-Type SMA Female cable
x1
RF Cable | RP-SMA Male to N-Type SMA Female | 300mm
SKU 100007236
High-quality low loss RG316 coaxial cable with durable FEP jacket, suitable for indoor and outdoor installation. Length 30cm (11.8'') with connectors RP-SMA Male to N-Type Female (Bulkhead).
Product Type
Products
USD$4.99
