- 10+: $4.20
Note
Feature
- Flexible MCU Board: Incorporate the ESP32-C3 32-bit RISC-V chip, operating up to 160 MHz, mounted multiple development ports, supported by Arduino / CircuitPython
- Outstanding RF performance: Implement complete Wi-Fi functions and Bluetooth Low Energy, while supporting communication over 100m with a U.FL antenna
- Elaborate Power Design: Provide 4 working modes as low as 44 μA in deep sleep mode, while supporting lithium battery charge management
- Thumb-sized Design: 21 x 17.5mm, Seeed Studio XIAO series classic form factor, suitable for wearable devices
Seeed Studio XIAO ESP32C3 has equipped a highly-integrated ESP32-C3 chip, built around a 32-bit RISC-V chip processor with a four-stage pipeline that operates at up to 160 MHz.
The board equips highly-integrated ESP32-C3 SoC. The chip has been installed with a complete 2.4GHz Wi-Fi subsystem which means it supports Station mode, SoftAP mode, SoftAP & Station mode, and promiscuous mode for multiple Wi-Fi applications. It works under an ultra-low power state, also supporting features of Bluetooth 5 and Bluetooth mesh. There are 400 KB SRAM & 4 MB Flash on the chip, allowing for more programming space, and bringing more possibilities to the IoT control scenarios.
Being a number to the Seeed Studio XIAO family, the board deservedly maintains the classic thumb-sized form-factor design and elegant productization of single-sided components mounting. Meanwhile, it has equipped with a battery charge chip and integrated circuit for enhancing its ability to carry. This board comes included with an external antenna to increase the signal strength for wireless applications. There are 11 digital I/O that can be used as PWM pins and 4 analog i/o that can be used as ADC pins. It supports UART, IIC, and SPI serial communication ports, also including IIS (Internet Information Services). Utilizing its small and exquisite hardware design and the powerful onboard chip, programming by Arduino, it will offer more ability to wearable and portable devices or other applications.
Attention
- It will be a little hard to connect the antenna at the first time using the board.
- Please connect the antenna at the vertical direction and do not drag at the horizontal direction.
Specification
Parameter | Description |
Processor | ESP32-C3 SoC |
RISC-V single-core 32-bit chip processor with a four-stage pipeline that operates at up to 160 MHz | |
Wireless | Complete 2.4GHz Wi-Fi subsystem |
Bluetooth 5.0/ Bluetooth mesh | |
On-chip Memory | 400KB SRAM & 4MB Flash |
Interface | 1x UART, 1x IIC, 1x IIS, 1x SPI,11x GPIO(PWM), 4x ADC |
1x Reset button, 1x Boot button | |
Dimensions | 21 x 17.5mm |
Power | Circuit operating voltage: [email protected] |
Charging current: 50mA/100mA | |
Input voltage (VIN): 5V | |
Deep Sleep Power Consumption | Deep Sleep Model: >44 μA |
Wi-Fi Enabled Power Consumption | Active Model: <75 mA |
Modem-sleep Model: <25 mA | |
Light-sleep Model: <4 mA | |
BLE Enabled Power Consumption | Modem-sleep Model: <27 mA |
Light-sleep Model: <10 mA | |
Working Temperature | -40°C ~ 85°C |
Application
- Internet of Things
- Wearable devices
- Health monitoring
- Education
- Low-Power(LP) networking
- Rapid prototyping
Materials: XIAO ESP32C3 *2, Grove - Button *1, Grove - Relay*1
Description:
This is a peer-to-peer WiFi communication application, since two XIAOs detect each other via Wifi, the garage door will open or keep opening, and vice versa.
Improvement:
It is nice to add an ultrasonic distance sensor to measure the car-to-door distance and an OLED screen to check the status of the garage. If you want an onboard voice sensor to command the door to open with vocal instruction, try our XIAO BLE Sense.
Materials: XIAO ESP32C3 *1, Grove - Wio - E5 *1, Grove - GPS *1
Description:
Thanks to the tiny size of the XIAO series, it is suitable to make the wearable devices, such as a small pet trackers. This wearable device can be used as a simple GPS-Tracker which will lock its current location and publish other data via LoRa.
Improvement:
A compass that shows direction and distance is a great added value to the tracker that you could consider. Meanwhile, publishing altitude, speed, or other parameters could bring more scenarios to this tracker. Besides, the chip ESP32-C3 allows this tracker to communicate over WiFi or BLE, and therefore, we can upload the tracker’s data or realize the Long Range-to-MQTT bridge as well.
Hardware Overview
Seeed Studio XIAO ESP32C3 | x1 |
Antenna | x1 |
HSCODE | 8543709990 |
USHSCODE | 8543709301 |
UPC | |
EUHSCODE | 8543709099 |
CE | 1 |
EU DoC | 1 |
FCC | 1 |
REACH | 1 |
RoHS | 1 |
TELEC | 1 |
UK DoC | 1 |
from order viewThis product meets expectations for the product and documentation, and shipping and receipt was faster than promised.
from order viewProduct came packaged well , delivery only 2 weeks . Came with headers and antenna
from order viewVery very excellent product! I love it... planning to order some more. Xiao esp32c3 is the best for the value.
from order viewLooks fine
